Subject: Re: Nightly builds
To: Amien Crombie <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 8 Sep 2017 16:10:07 +0000
Sorry, email went out on its own..
>I'm currently using CSS 4.5 nightly builds and initially installed
>Subverse and Pydev.
>When I do a download of the latest build, how can I then update my CSS
>without re-installing my 2 plugins?
When you download the nightly build from https://ics-web.sns.ornl.gov/css/nightly,
note that there's also an update repo,  https://ics-web.sns.ornl.gov/css/nightly/repo/
So if you downloaded the nightly snapshot 3 weeks ago,
in principle you can run that,
open Help/Install New Software,
either enter a new update site  for https://ics-web.sns.ornl.gov/css/nightly/repo/,
or edit the "SNS update site" under "Available Software Sites"
into   https://ics-web.sns.ornl.gov/css/nightly/repo/.
If you edit the "SNS update site" to the nightly repo, this will have the advantage or drawback that whenever you start CSS, it might prompt you "There's an update available, do you want to install.." every couple of days unless you disable the automated update check in the preferences.
-Kay
Re: Nightly builds Amien Crombie
Re: Nightly builds Kasemir, Kay
Prev: Re: Nightly builds Kasemir, Kay
Next: Re: Nightly builds Amien Crombie
