1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Nightly builds
To: "Kasemir, Kay" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 8 Sep 2017 18:18:09 +0200
Hi Kay
Yes, it works...thanks
I missed the repo dir
Amien
On 08/09/2017 18:10, Kasemir, Kay wrote:
Sorry, email went out on its own..
I'm currently using CSS 4.5 nightly builds and initially installed
Subverse and Pydev.
When I do a download of the latest build, how can I then update my CSS
without re-installing my 2 plugins?
When you download the nightly build from https://ics-web.sns.ornl.gov/css/nightly,
note that there's also an update repo,  https://ics-web.sns.ornl.gov/css/nightly/repo/
So if you downloaded the nightly snapshot 3 weeks ago,
in principle you can run that,
open Help/Install New Software,
either enter a new update site  for https://ics-web.sns.ornl.gov/css/nightly/repo/,
or edit the "SNS update site" under "Available Software Sites"
into   https://ics-web.sns.ornl.gov/css/nightly/repo/.
If you edit the "SNS update site" to the nightly repo, this will have the advantage or drawback that whenever you start CSS, it might prompt you "There's an update available, do you want to install.." every couple of days unless you disable the automated update check in the preferences.
-Kay
Nightly builds Amien Crombie
Re: Nightly builds Kasemir, Kay
Prev: Re: Nightly builds Kasemir, Kay
Next: mca R7-7 now available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
