Subject: Re: data refresh and add pv
To: 梁雅翔 <[email protected]>, tech-talk <[email protected]>
Date: Mon, 11 Sep 2017 22:00:10 +0000
Hi Liang,
Which OS are you using, and which A&A version do you use?
1.
Fo you want to know the the latest archived PV value? Or the live value from a PV?
If you mean the live value, it might be convenient to use a display manager tool like CS-Studio, EDM/MEDM to monitor your PV value changes.
2.
I am assuming that you are using the "mgmt/ui/index.html” page.
Do you have any more detail when you “it did not work well”?
For example, if you want to see the PV in your archiver, you could just put a “*” there, and click the check status button.
Hope this is helpful.
Guobao
From: <[email protected]> on behalf of 梁雅翔 <[email protected]>
Date: Friday, September 8, 2017 at 5:18 AM
To: tech-talk <[email protected]>
Subject: data refresh and add pv
Hi all,
    I am using epicsarchiver ( http://slacmshankar.github.io/epicsarchiver_docs/quickstart.html ) , I started it with Quickstart.
    It worked well, but I have two small questions :
1. The pv didn't refresh automatically( Actually, it did changed ).   I need to refresh the firefox web when I want to know the newest status of PV.
  Then I make the firefox refresh every second, it worked, but the screen twinkle every second, not very well.
  Does someone have better way make the pv refresh antomatically?
2. There is "add PV" in top right corner. It did not worked well. I tried it, no another pv display in web.
  Could anyone tell me what is the wrong with it?
Liang yx
data refresh and add pv 梁雅翔
Prev: Automatic refresh of OPI Iain Marcuson
Next: Cannot communicate with S7-400 Antal, Szabolcs
Prev: data refresh and add pv 梁雅翔
Next: StreamDevice hexa checksum in lowercase characters Paduan Donadio, Marcio
