My IOC has a group of parameters that are internally set and get as a group, owing to the design of the backend. The user may want to change only one of the parameters, but the others must be set at the same time. The setter uses Text Input widgets, while the getter uses Text Update widgets. I have set up the getter to populate the setter widgets, allowing quick modification of just one parameter. However, in order for the Text Input widgets to show the values from the getter, I need to refresh the OPI. Is there a way to automate that. Toggling GUIUtil.compactMode() as suggested at http://www.aps.anl.gov/epics/tech-talk/2016/msg00154.php did not refresh the widgets.
Thank you,
Iain.
- Re: Automatic refresh of OPI Kasemir, Kay
mca R7-7 now available Mark Rivers
Re: data refresh and add pv Shen, Guobao
<2017>
2025
2026
<2017>
2025
2026
