Subject: MEDM display of string records not updating from PCASpy/PyEpics
To: EPICS mailing list <[email protected]>
Date: Tue, 12 Sep 2017 11:52:29 -0500
Dear all
	We have an odd behavior here with a continuously-running MEDM display.
In most cases, where the EPICS IOC is running in C or similar, the MEDM displays of string variables happily update when the underlying PV is updated.
However, we have a simple EPICS database that is done with PCASpy. We then use a pyEpics client to regularly update records in the EPICS database using pvPut().
The updated numeric records all work fine.  However, the string records (when updated) appear as 00.00 or similar in the MEDM display.
If we open a new MEDM display, the correct value is shown.  If we slightly resize the MEDM display, it also updates.
Any idea what is going on?
Is there something in the PCASpy database record fields we need to set to make this work?
- Using command-line caput() we get updated values.
— I was going to try an MEDM->caQtDM conversion to see if we get any different behavior.
Thanks
	Keith Thorne
Keith Thorne <[email protected]>
CDS Software Engineer
LIGO Livingston Laboratory
Livingston, LA 70754
Phone: (225)686-3168 Fax: (225)686-7189
RE: MEDM display of string records not updating from PCASpy/PyEpics Mark Rivers
Prev: Re: Automatic refresh of OPI Andrew Johnson
Next: RE: MEDM display of string records not updating from PCASpy/PyEpics Mark Rivers
Prev: Re: How to use Archiver Appliance to archive PVs of only the latest period of time Shankar, Murali
