Hi Keith,
Some questions:
- What does command line cainfo say about that PV?
- What does command line caget show for that PV?
- In your medm display what "Format" have you selected for the text update widget, e.g. "decimal", "string", etc.?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of keith.thorne
Sent: Tuesday, September 12, 2017 11:52 AM
To: EPICS mailing list
Subject: MEDM display of string records not updating from PCASpy/PyEpics
Dear all
We have an odd behavior here with a continuously-running MEDM display.
In most cases, where the EPICS IOC is running in C or similar, the MEDM displays of string variables happily update when the underlying PV is updated.
However, we have a simple EPICS database that is done with PCASpy. We then use a pyEpics client to regularly update records in the EPICS database using pvPut().
The updated numeric records all work fine. However, the string records (when updated) appear as 00.00 or similar in the MEDM display.
If we open a new MEDM display, the correct value is shown. If we slightly resize the MEDM display, it also updates.
Any idea what is going on?
Is there something in the PCASpy database record fields we need to set to make this work?
- Using command-line caput() we get updated values.
— I was going to try an MEDM->caQtDM conversion to see if we get any different behavior.
Thanks
Keith Thorne
Keith Thorne <[email protected]>
CDS Software Engineer
LIGO Livingston Laboratory
Livingston, LA 70754
Phone: (225)686-3168 Fax: (225)686-7189
- Re: MEDM display of string records not updating from PCASpy/PyEpics keith.thorne
- MEDM display of string records not updating from PCASpy/PyEpics keith.thorne
<2017>
2025
2026
<2017>
2025
2026
