Subject: Re: MEDM display of string records not updating from PCASpy/PyEpics
Cc: EPICS mailing list <[email protected]>
Date: Tue, 12 Sep 2017 13:34:13 -0500
Dear Mark
The cainfo looks fine, with “Native data type: DBF_STRING” and “Request type: DBR_STRING”.  command-line caget comes backs with a string.
Of course, the MEDM text monitor says Format “decimal’.  I tried to use the MEDM editor to save it as “string" but see no change in the underlying *.adl file.
But according to the MEDM manual, it will always think it is a number, even for ‘string’.
These strings are typically longer than a numeric field (up to 40 characters), so I guess it puts out 00.00 as ‘exponential’ notation when there are too many characters?
So, what is the way to display string fields for a PV in MEDM?
Thanks
	Keith
> On Sep 12, 2017, at 12:21 PM, Mark Rivers <[email protected]> wrote:
> Hi Keith,
> Some questions:
> - What does command line cainfo say about that PV?
> - What does command line caget show for that PV?
> - In your medm display what "Format" have you selected for the text update widget, e.g. "decimal", "string", etc.?
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of keith.thorne
> Sent: Tuesday, September 12, 2017 11:52 AM
> To: EPICS mailing list
> Subject: MEDM display of string records not updating from PCASpy/PyEpics
> Dear all
> 	We have an odd behavior here with a continuously-running MEDM display.
> In most cases, where the EPICS IOC is running in C or similar, the MEDM displays of string variables happily update when the underlying PV is updated.
> However, we have a simple EPICS database that is done with PCASpy. We then use a pyEpics client to regularly update records in the EPICS database using pvPut().
> The updated numeric records all work fine.  However, the string records (when updated) appear as 00.00 or similar in the MEDM display.
> If we open a new MEDM display, the correct value is shown.  If we slightly resize the MEDM display, it also updates.
> Any idea what is going on?
> Is there something in the PCASpy database record fields we need to set to make this work?
> - Using command-line caput() we get updated values.
> — I was going to try an MEDM->caQtDM conversion to see if we get any different behavior.
> Thanks
> 	Keith Thorne
> Keith Thorne <[email protected]>
> CDS Software Engineer
> LIGO Livingston Laboratory
> Livingston, LA 70754
> Phone: (225)686-3168 Fax: (225)686-7189
Re: MEDM display of string records not updating from PCASpy/PyEpics Andrew Johnson
RE: MEDM display of string records not updating from PCASpy/PyEpics Mark Rivers
MEDM display of string records not updating from PCASpy/PyEpics keith.thorne
Prev: RE: MEDM display of string records not updating from PCASpy/PyEpics Mark Rivers
Next: Re: MEDM display of string records not updating from PCASpy/PyEpics Andrew Johnson
