Subject: Re: Help creating motorR6-9 examples
From: Guilherme Jovanini Montagner <[email protected]>
To: "Ronald L. Sluiter" <[email protected]>
Date: Tue, 12 Sep 2017 17:12:35 -0300 (BRT)
Hi Ron.
Thanks for the reply!
On the SoftMotorSrc folder, there is no "O.Common" neither "O,linux-x86_64" directories.
(the output of ls is "devSoftAux.cc   devSoft.cc   devSoft.h   devSoftMotor.dbd   Makefile")
Also, on the top dbd folder, there is no "devSoftMotor.dbd" file
(the output of ls is "motorRecord.dbd   motorSupport.dbd   PI_GCS2Support.dbd")
Did I skip something?
Thanks
+55 19 2517.8911
+55 19 99806.9117
[email protected]
----- Mensagem original -----
De: "Ronald L. Sluiter" <[email protected]>
Para: "guilherme" <[email protected]>, "tech-talk" <[email protected]>
Enviadas: Terça-feira, 12 de setembro de 2017 16:57:30
Assunto: Re: Help creating motorR6-9 examples
Hello Guilherme,
I am guessing that the SoftMotorSrc directory did not get built. If you 'ls' the
SoftMotorSrc directory you should get this;
> % ls motorApp/SoftMotorSrc
> devSoftAux.cc  devSoft.cc  devSoft.h  devSoftMotor.dbd  Makefile  O.Common
> O.linux-x86_64
and there should be a 'devSoftMotor.dbd' file installed in the top 'dbd' directory.
> galadriel% ls dbd
> ACRMotorSupport.dbd  devDeltaTau.dbd        devMclennanMotor.dbd
> devNewport.dbd  devPIJena.dbd *devSoftMotor.dbd*  MicronixSupport.dbd
> motorSupport.dbd         omsAsynSupport.dbd
> devAcsMotor.dbd      devFaulhaberMotor.dbd  devMicos.dbd devOms.dbd
> devPIMotor.dbd      devSPiiPlus.dbd  motorRecord.dbd      NoAsyn.dbd
>       phytron.dbd
> devAerotech.dbd      devImsMotor.dbd        devMicroMo.dbd devOriel.dbd
> devSmarActMCSMotor.dbd  devThorLabs.dbd  motorSim.dbd         NoAsynVx.dbd
>       PI_GCS2Support.dbd
> devAttocube.dbd      devKohzuMotor.dbd        devNewFocus.dbd devPC6K.dbd
> devSmartMotorMotor.dbd  HytecMotorDriver.dbd  motorSimSupport.dbd
> NPointMotorSupport.dbd
What do you see in those two directories?
Ron
On 09/12/2017 02:25 PM, Guilherme Jovanini Montagner wrote:
> Hi!
> I'm involved in a Project in which EPICS is to be used, and am currently
> trying to create a working example using a PI piezo controller.
> I want some help doing this.
> I've uncommented the lines
> DIRS += motorExApp iocBoot
> motorExApp_DEPEND_DIRS = motorApp
> iocBoot_DEPEND_DIRS = motorExApp
> from the top makefile. I've also uncommented the line "MOTOR=$(TOP)" in
> configure/RELEASE file
> Also, on the file motorApp/Makefile, I've got the lines
> DIRS +=PIGCS2Src
> PIGCS2Src_DEPEND_DIRS = MotorSrc
> uncommented.
> The problem is, when I run make on top, I get the following message:
> [setup@localhost motorExApp]$ make
> make -C ./NoAsyn install
> make[1]: Entering directory
> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
>     T_A=linux-x86_64 install
> make[2]: Entering directory
> `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
> Creating dbd file NoAsyn.dbd
> perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl -I.
> -I.. -I../O.Common -I../../../dbd -I/home/setup/Downloads/support/asyn4-31/dbd
> -I/home/setup/Downloads/base-3.16.1/dbd -o NoAsyn.dbd base.dbd motorRecord.dbd
> devSoftMotor.dbd Misc.dbd
> dbdExpand.pl: Can't find file 'devSoftMotor.dbd'
>   while reading 'devSoftMotor.dbd' to create 'NoAsyn.dbd'
>   Your Makefile may need this dependency rule:
>     $(COMMON_DIR)/NoAsyn.dbd: $(COMMON_DIR)/devSoftMotor.dbd
> dbdExpand.pl: Exiting due to errors
> make[2]: *** [../O.Common/NoAsyn.dbd] Error 255
> make[2]: Leaving directory
> make[1]: *** [install.linux-x86_64] Error 2
> make[1]: Leaving directory
> make: *** [NoAsyn.install] Error 2
> Then, I proceeded to add the mentioned line on motorExApp/NoAsyn/Makefile:
>  ADD MACRO DEFINITIONS AFTER THIS LINE
> PROD_IOC_DEFAULT = NoAsyn
> PROD_IOC_vxWorks = NoAsynVx
> COMMONDBDS  = base.dbd
> COMMONDBDS += motorRecord.dbd
> COMMONDBDS += devSoftMotor.dbd
> #!COMMONDBDS += devMXmotor.dbd
> but when I run make again, after doing that, I get the following error:
> Creating dbd file devSoftMotor.dbd
> -I/home/setup/Downloads/base-3.16.1/dbd -o devSoftMotor.dbd
> dbdExpand.pl: No input files for devSoftMotor.dbd
> make[2]: *** [../O.Common/devSoftMotor.dbd] Error 255
> I don't know where is this devSoftMotor.dbd being called, and why it doesn't
> have input arguments.
> Could you help me, please?
> Thanks,
> Guilherme
> *Guilherme Jovanini Montagner*
> +55 19 2517.8911
> +55 19 99806.9117
> [email protected]
Help creating motorR6-9 examples Guilherme Jovanini Montagner
Re: Help creating motorR6-9 examples Ronald L. Sluiter
Prev: Re: Help creating motorR6-9 examples Ronald L. Sluiter
Next: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Prev: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Next: Fwd: Re: Help creating motorR6-9 examples Ronald L. Sluiter
