Subject: Re: Help creating motorR6-9 examples
To: Guilherme Jovanini Montagner <[email protected]>, <[email protected]>
Date: Tue, 12 Sep 2017 14:57:30 -0500
Hello Guilherme,
I am guessing that the SoftMotorSrc directory did not get built. If you 'ls' the SoftMotorSrc directory you should get this;
% ls motorApp/SoftMotorSrc
devSoftAux.cc devSoft.cc devSoft.h devSoftMotor.dbd Makefile O.Common O.linux-x86_64
and there should be a 'devSoftMotor.dbd' file installed in the top 'dbd' directory.
galadriel% ls dbd
ACRMotorSupport.dbd devDeltaTau.dbd devMclennanMotor.dbd devNewport.dbd devPIJena.dbd *devSoftMotor.dbd* MicronixSupport.dbd motorSupport.dbd omsAsynSupport.dbd devAcsMotor.dbd devFaulhaberMotor.dbd devMicos.dbd devOms.dbd devPIMotor.dbd devSPiiPlus.dbd motorRecord.dbd NoAsyn.dbd phytron.dbd devAerotech.dbd devImsMotor.dbd devMicroMo.dbd devOriel.dbd devSmarActMCSMotor.dbd devThorLabs.dbd motorSim.dbd NoAsynVx.dbd PI_GCS2Support.dbd devAttocube.dbd devKohzuMotor.dbd devNewFocus.dbd devPC6K.dbd devSmartMotorMotor.dbd HytecMotorDriver.dbd motorSimSupport.dbd NPointMotorSupport.dbd
What do you see in those two directories?
Ron
On 09/12/2017 02:25 PM, Guilherme Jovanini Montagner wrote:
Hi!
I'm involved in a Project in which EPICS is to be used, and am currently trying to create a working example using a PI piezo controller.
I want some help doing this.
I've uncommented the lines
DIRS += motorExApp iocBoot
motorExApp_DEPEND_DIRS = motorApp
iocBoot_DEPEND_DIRS = motorExApp
from the top makefile. I've also uncommented the line "MOTOR=$(TOP)" in configure/RELEASE file
Also, on the file motorApp/Makefile, I've got the lines
DIRS +=PIGCS2Src
PIGCS2Src_DEPEND_DIRS = MotorSrc
uncommented.
The problem is, when I run make on top, I get the following message:
[setup@localhost motorExApp]$ make
make -C ./NoAsyn install
make[1]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
Creating dbd file NoAsyn.dbd
perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/setup/Downloads/support/asyn4-31/dbd -I/home/setup/Downloads/base-3.16.1/dbd -o NoAsyn.dbd base.dbd motorRecord.dbd devSoftMotor.dbd Misc.dbd
dbdExpand.pl: Can't find file 'devSoftMotor.dbd'
  while reading 'devSoftMotor.dbd' to create 'NoAsyn.dbd'
  Your Makefile may need this dependency rule:
    $(COMMON_DIR)/NoAsyn.dbd: $(COMMON_DIR)/devSoftMotor.dbd
dbdExpand.pl: Exiting due to errors
make[2]: *** [../O.Common/NoAsyn.dbd] Error 255
make[2]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
make: *** [NoAsyn.install] Error 2
Then, I proceeded to add the mentioned line on motorExApp/NoAsyn/Makefile:
 ADD MACRO DEFINITIONS AFTER THIS LINE
PROD_IOC_DEFAULT = NoAsyn
PROD_IOC_vxWorks = NoAsynVx
COMMONDBDS  = base.dbd
COMMONDBDS += motorRecord.dbd
COMMONDBDS += devSoftMotor.dbd
#!COMMONDBDS += devMXmotor.dbd
but when I run make again, after doing that, I get the following error:
Creating dbd file devSoftMotor.dbd
perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/setup/Downloads/support/asyn4-31/dbd -I/home/setup/Downloads/base-3.16.1/dbd -o devSoftMotor.dbd
dbdExpand.pl: No input files for devSoftMotor.dbd
make[2]: *** [../O.Common/devSoftMotor.dbd] Error 255
I don't know where is this devSoftMotor.dbd being called, and why it doesn't have input arguments.
Could you help me, please?
Guilherme
*Guilherme Jovanini Montagner*
+55 19 2517.8911
+55 19 99806.9117
[email protected]
Re: Help creating motorR6-9 examples Ronald L. Sluiter
Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Prev: Re: MEDM display of string records not updating from PCASpy/PyEpics keith.thorne
Next: Re: Help creating motorR6-9 examples Ronald L. Sluiter
Prev: Help creating motorR6-9 examples Guilherme Jovanini Montagner
