1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM display of string records not updating from PCASpy/PyEpics
Cc: EPICS mailing list <[email protected]>
Date: Tue, 12 Sep 2017 14:44:04 -0500
Dear Mark
	I actually manually entered that in text text of the MEDM file (the editor would not save it), but did not seem to matter.
I will try that again, of course.
	Keith
> On Sep 12, 2017, at 2:36 PM, Mark Rivers <[email protected]> wrote:
> Hi Keith,
> There is a big difference between setting the medm Format=decimal vs Format=string.
> Here is a screen shot of an medm screen I just created.  The blue text widgets are both looking at the same PV, but the upper one has Format=string, the lower one has Format=decimal.  This is important with long strings, i.e. those in waveform records in a normal IOC.
> <image001.png>
> There is a difference in the adl file for these 2 widgets.  Note format="string" in the second one.
> "text update" {
>         object {
>                 x=155
>                 y=53
>                 width=300
>                 height=20
>         monitor {
>                 chan="13BMC-PIL:netCDF1:FilePath_RBV"
>                 clr=53
>                 bclr=4
>         limits {
> "text update" {
>         object {
>                 x=155
>                 y=28
>                 width=300
>                 height=20
>         monitor {
>                 clr=53
>                 bclr=4
>         format="string"
>         limits {
> Mark
> -----Original Message-----
> From: keith.thorne [mailto:[email protected]]
> Sent: Tuesday, September 12, 2017 1:34 PM
> To: Mark Rivers
> Dear Mark
> The cainfo looks fine, with “Native data type: DBF_STRING” and “Request type: DBR_STRING”.  command-line caget comes backs with a string.
> Of course, the MEDM text monitor says Format “decimal’.  I tried to use the MEDM editor to save it as “string" but see no change in the underlying *.adl file.
> But according to the MEDM manual, it will always think it is a number, even for ‘string’.
> These strings are typically longer than a numeric field (up to 40 characters), so I guess it puts out 00.00 as ‘exponential’ notation when there are too many characters?
> So, what is the way to display string fields for a PV in MEDM?
> Thanks
>             Keith
> > On Sep 12, 2017, at 12:21 PM, Mark Rivers <[email protected]> wrote:
> > Hi Keith,
> > Some questions:
> > - What does command line cainfo say about that PV?
> > - What does command line caget show for that PV?
> > - In your medm display what "Format" have you selected for the text update widget, e.g. "decimal", "string", etc.?
> > Mark
> > From: [email protected] [mailto:[email protected]] On Behalf Of keith.thorne
> > Sent: Tuesday, September 12, 2017 11:52 AM
> > To: EPICS mailing list
> > Subject: MEDM display of string records not updating from PCASpy/PyEpics
> > Dear all
> >          We have an odd behavior here with a continuously-running MEDM display.
> > In most cases, where the EPICS IOC is running in C or similar, the MEDM displays of string variables happily update when the underlying PV is updated.
> > However, we have a simple EPICS database that is done with PCASpy. We then use a pyEpics client to regularly update records in the EPICS database using pvPut().
> > The updated numeric records all work fine.  However, the string records (when updated) appear as 00.00 or similar in the MEDM display.
> > If we open a new MEDM display, the correct value is shown.  If we slightly resize the MEDM display, it also updates.
> > Any idea what is going on?
> > Is there something in the PCASpy database record fields we need to set to make this work?
> > - Using command-line caput() we get updated values.
> > — I was going to try an MEDM->caQtDM conversion to see if we get any different behavior.
> > Thanks
> >          Keith Thorne
> > Keith Thorne <[email protected]>
> > CDS Software Engineer
> > LIGO Livingston Laboratory
> > Livingston, LA 70754
> > Phone: (225)686-3168 Fax: (225)686-7189
MEDM display of string records not updating from PCASpy/PyEpics keith.thorne
RE: MEDM display of string records not updating from PCASpy/PyEpics Mark Rivers
Re: MEDM display of string records not updating from PCASpy/PyEpics keith.thorne
Prev: RE: MEDM display of string records not updating from PCASpy/PyEpics Mark Rivers
Next: Re: Help creating motorR6-9 examples Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Help creating motorR6-9 examples Guilherme Jovanini Montagner
