Subject: Re: Help creating motorR6-9 examples
To: Guilherme Jovanini Montagner <[email protected]>
Date: Tue, 12 Sep 2017 15:17:16 -0500
Could you run the following command at the top directory,
make >& makedump.txt
and send me the file.
Ron
On 09/12/2017 03:13 PM, Guilherme Jovanini Montagner wrote:
Hi again. Yes, I have run make from the top, and after, tried running it again from the child directory.
+55 19 2517.8911
+55 19 99806.9117
[email protected]
----- Mensagem original -----
De: "Ronald L. Sluiter" <[email protected]>
Para: "guilherme" <[email protected]>, "tech-talk" <[email protected]>
Enviadas: Terça-feira, 12 de setembro de 2017 17:06:32
Assunto: Re: Help creating motorR6-9 examples
If you did not run "make" from the top level "motorR6-9" directory, that could
be why you are getting these errors. The EPICS motor module, like EPICS base and
most other EPICS modules, assumes that "make" is run 1st from the top level
directory. After running 'make' from the top level you can make custom changes
and taylor the module to your specific needs, but you should run make from the
top 1st.
Ron
On 09/12/2017 02:57 PM, Ronald L. Sluiter wrote:
Hello Guilherme,
I am guessing that the SoftMotorSrc directory did not get built. If you 'ls'
the SoftMotorSrc directory you should get this;
% ls motorApp/SoftMotorSrc
devSoftAux.cc  devSoft.cc  devSoft.h  devSoftMotor.dbd Makefile  O.Common
O.linux-x86_64
and there should be a 'devSoftMotor.dbd' file installed in the top 'dbd'
directory.
galadriel% ls dbd
ACRMotorSupport.dbd  devDeltaTau.dbd        devMclennanMotor.dbd
devNewport.dbd  devPIJena.dbd *devSoftMotor.dbd* MicronixSupport.dbd
motorSupport.dbd         omsAsynSupport.dbd
devAcsMotor.dbd      devFaulhaberMotor.dbd  devMicos.dbd devOms.dbd
devPIMotor.dbd      devSPiiPlus.dbd motorRecord.dbd      NoAsyn.dbd
       phytron.dbd
devAerotech.dbd      devImsMotor.dbd        devMicroMo.dbd devOriel.dbd
devSmarActMCSMotor.dbd  devThorLabs.dbd motorSim.dbd         NoAsynVx.dbd
       PI_GCS2Support.dbd
devAttocube.dbd      devKohzuMotor.dbd        devNewFocus.dbd
devPC6K.dbd      devSmartMotorMotor.dbd  HytecMotorDriver.dbd
motorSimSupport.dbd  NPointMotorSupport.dbd
What do you see in those two directories?
Ron
On 09/12/2017 02:25 PM, Guilherme Jovanini Montagner wrote:
Hi!
I'm involved in a Project in which EPICS is to be used, and am currently
trying to create a working example using a PI piezo controller.
I want some help doing this.
I've uncommented the lines
DIRS += motorExApp iocBoot
motorExApp_DEPEND_DIRS = motorApp
iocBoot_DEPEND_DIRS = motorExApp
from the top makefile. I've also uncommented the line "MOTOR=$(TOP)" in
configure/RELEASE file
Also, on the file motorApp/Makefile, I've got the lines
DIRS +=PIGCS2Src
PIGCS2Src_DEPEND_DIRS = MotorSrc
uncommented.
The problem is, when I run make on top, I get the following message:
[setup@localhost motorExApp]$ make
make -C ./NoAsyn install
make[1]: Entering directory
`/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
     T_A=linux-x86_64 install
make[2]: Entering directory
`/home/setup/Downloads/support/motor/motorR6-9/motorExApp/NoAsyn/O.linux-x86_64'
Creating dbd file NoAsyn.dbd
perl -CSD /home/setup/Downloads/base-3.16.1/bin/linux-x86_64/dbdExpand.pl -I.
-I.. -I../O.Common -I../../../dbd
-I/home/setup/Downloads/support/asyn4-31/dbd
-I/home/setup/Downloads/base-3.16.1/dbd -o NoAsyn.dbd base.dbd
motorRecord.dbd devSoftMotor.dbd Misc.dbd
dbdExpand.pl: Can't find file 'devSoftMotor.dbd'
   while reading 'devSoftMotor.dbd' to create 'NoAsyn.dbd'
   Your Makefile may need this dependency rule:
     $(COMMON_DIR)/NoAsyn.dbd: $(COMMON_DIR)/devSoftMotor.dbd
dbdExpand.pl: Exiting due to errors
make[2]: *** [../O.Common/NoAsyn.dbd] Error 255
make[2]: Leaving directory
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory
make: *** [NoAsyn.install] Error 2
Then, I proceeded to add the mentioned line on motorExApp/NoAsyn/Makefile:
  ADD MACRO DEFINITIONS AFTER THIS LINE
PROD_IOC_DEFAULT = NoAsyn
PROD_IOC_vxWorks = NoAsynVx
COMMONDBDS  = base.dbd
COMMONDBDS += motorRecord.dbd
COMMONDBDS += devSoftMotor.dbd
#!COMMONDBDS += devMXmotor.dbd
but when I run make again, after doing that, I get the following error:
Creating dbd file devSoftMotor.dbd
-I/home/setup/Downloads/base-3.16.1/dbd -o devSoftMotor.dbd
dbdExpand.pl: No input files for devSoftMotor.dbd
make[2]: *** [../O.Common/devSoftMotor.dbd] Error 255
I don't know where is this devSoftMotor.dbd being called, and why it doesn't
have input arguments.
Could you help me, please?
Guilherme
*Guilherme Jovanini Montagner*
+55 19 2517.8911
+55 19 99806.9117
[email protected]
Re: Help creating motorR6-9 examples Pete Jemian
Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Re: Help creating motorR6-9 examples Ronald L. Sluiter
Prev: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Next: Re: Help creating motorR6-9 examples Guilherme Jovanini Montagner
Next: Re: Help creating motorR6-9 examples Pete Jemian
