1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: QtQuick + EPICS PV = CSDataQuick
To: Epics <[email protected]>
Cc: Sebastian Steinlechner <[email protected]>
Date: Fri, 15 Sep 2017 18:27:07 +0000
Hi all,
QML/QtQuick has made easy the creation of fluid, dynamic GUI programs through a declarative syntax.
I started to experiment the EPICS integration since its introduction and intermittently made improvements
as the technology develops.
The result is a qml module CSDataQuick [1], consisting of two submodules:
  * CSDataQuick.Data: the CSData object and the data engine plugin system.
  * CSDataQuick.Components: the standard visual items.
Built upon that is a ADLViewer to display ADL/QML files, and a builder to build throwaway GUIs on-the-fly.
Check out the documents [2] to get started. For the impatient, there is ready-to-use Anaconda binary packages.
	$ conda install -c paulscherrerinstitute csdataquick
See more about that in the installation section.
This module is of beta quality. Feel free to reports problems and start discussions in the issue tracker.[3]
Best
Xiaoqiang
[1] https://github.com/xiaoqiangwang/CSDataQuick
[2] https://xiaoqiangwang.github.io/CSDataQuick-doc
[3] https://github.com/xiaoqiangwang/CSDataQuick/issues
Prev: Modbus R2-10 available Mark Rivers
Next: acctst failure Al Honey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
