1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: acctst failure
Date: Fri, 15 Sep 2017 20:40:12 +0000
Hi
I am running the acctst (r3.14.12.5) on a softIOC (REHLv7).
acctst timerperiod 2 1 10 1
where timerperiod is an analog output record with DTYP of Soft Channel
Everything runs fine up until the caTaskExitTest (see below).
Any ideas as to why ca_task_exit() would cause a segmentation fault.
Thx,
Al
verifyAnalogIO {} 0.019500 sec
verifyAnalogIO {} 0.017648 sec
multiSubscriptionDeleteTest {...} 0.080886 sec
singleSubscriptionDeleteTest {..........} 0.842084 sec
channelClearWithEventTrafficTest {} 27.055007 sec
monitorUpdateTest {...} 1.107345 sec
verifyHighThroughputRead {} 0.003613 sec
verifyHighThroughputWrite {} 0.000780 sec
verifyHighThroughputReadCallback {} 0.101164 sec
verifyHighThroughputWriteCallback {} 0.101897 sec
verifyBadString {Test fails if stim "8" isnt roughly equiv to resp "8.000000"
} 0.000064 sec
verifyMultithreadSubscr {.} 0.097351 sec
CA pend event delay = 1.000000 sec results in error = 0.012294 %
CA pend event delay = 0.100000 sec results in error = 0.111641 %
CA pend event delay = 0.250000 sec results in error = 0.051082 %
ca_client_context at 0xf0bcd0 pndRecvCnt=0 ioSeqNo=4371
verifyConnectionHandlerConnect {........................................} 1.002006 sec
verifyBlockingConnect {........................................} 0.370005 sec
verifyClear {} 0.000008 sec
verifyReasonableBeaconPeriod {Beacon anomalies detected since program start 7
Estimated beacon period for channel ss1:om1s:timerperiod = -1.79769e+308 sec.
busy: receive watchdog for "ss1:om1s:timerperiod" expires in 29.9219 sec.
inactive: receive watchdog for "ss1:om1s:timerperiod" expires in 29.9887 sec.
} 30.001885 sec
caTaskExitTest {Segmentation fault (core dumped)
Re: acctst failure Andrew Johnson
Prev: QtQuick + EPICS PV = CSDataQuick Wang Xiaoqiang (PSI)
Next: Modbus R2-10-1 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: acctst failure Andrew Johnson
