1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus R2-10-1 available
To: Mark Rivers <[email protected]>, epics Techtalk <[email protected]>
Date: Fri, 15 Sep 2017 20:44:03 +0000
Folks,
Just after releasing R2-10 this morning I realized there was an important outstanding pull request.  I have merged it and done some testing, so I am now releasing 2-10-1.
This is the new item from the release notes:
- Previously the Modbus/TCP transaction ID was set to 1 on writes and ignored on reads.
  Now the Modbus transaction ID is incremented by 1 on each message sent by the driver.
  On the reply the driver waits until a message with the correct transaction ID is received, ignoring messages with any other transaction ID.
  This is more robust, especially for Modbus/UDP links. Thanks to Eric Norum for this.
This change assumes that the Modbus server correctly implements the Modbus/TCP specification which requires it to echo back the transaction ID that it receives.  I have tested this on several Modbus servers.  If in the future we find that there are non-compliant Modbus servers then we can add an option to disable the check on the received messages.
The home page is here:
http://cars.uchicago.edu/software/epics/modbus.html
The release notes are here:
http://cars.uchicago.edu/software/epics/modbusReleaseNotes.html
The documentation is here:
http://cars.uchicago.edu/software/epics/modbusDoc.html
The repository is on Github:
https://github.com/epics-modules/modbus
Prev: acctst failure Al Honey
Next: Re: acctst failure Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: acctst failure Andrew Johnson
Next: New versions of ipUnidig, ip330, and dac128V modules have been released Mark Rivers
