1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: dbVerify removed from EPICS 3.16
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Wed, 20 Sep 2017 06:43:53 +0000
Hmm.  An external linting problem doesn't fit my application very well.
How do you validate field assignments in your application, Michael?  I need to be able to do something like the following:
>>> a = records.ao('TEST')
>>> a.DRVL = 'wrong'
AssertionError: Can't write "test" to field DRVL: not a number
>>> a.DRVL = 123
>>> a.SCAN = 'wrong'
AssertionError: Can't write "wrong" to field SCAN: Not a valid menu choice
>>> a.SCAN = '.1 second'
From: Michael Davidsaver [mailto:[email protected]]
> If you're interested in static validation of db/dbd files, you might
> have a look at my 'dbdlint' script.  This can either validate individual
> files for basic syntax (--partial), or a full database w/ recordtype
> defs (--full).
> This includes a handy (to me) feature to detect unintentional "external"
> links (aka typos).
> > $ cat test.db
> > #: external("other.VAL")
> > record(longin, "target") {
> >     field(INP, "other")
> > record(longin, "ok") {
> >     field(INP, "targt") # oops
> > $ ./dbdlint -F -Wall /path/to/base/dbd/softIoc.dbd test.db
> > WARNING test.db:8 ext-link - DB/CA Link to outside PV 'targt.VAL'
> https://github.com/epicsdeb/pypdb/blob/master/documentation/dbdlint.rst
> https://github.com/epicsdeb/pypdb/blob/master/dbdlint.1.txt
> On 09/19/2017 01:00 PM, Andrew Johnson wrote:
> > Hi Michael,
> > On 09/19/2017 04:34 AM, [email protected] wrote:
> >> I have just discovered that the dbVerify function has been removed from
> >> EPICS 3.16.  I use the functionality provided by this function to
> >> validate databases as they are statically constructed (in iocbuilder
> >> and epicsdbbuilder).  At present DLS is still using EPICS 3.14, so I am
> >> only learning about this from external reports.
Re: dbVerify removed from EPICS 3.16 Michael Davidsaver
dbVerify removed from EPICS 3.16 michael.abbott
Re: dbVerify removed from EPICS 3.16 Andrew Johnson
Prev: RE: dbVerify removed from EPICS 3.16 michael.abbott
Next: Build change from 3.14 to 3.15 michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbVerify removed from EPICS 3.16 Michael Davidsaver
Next: Re: dbVerify removed from EPICS 3.16 Michael Davidsaver
