On 09/20/2017 01:43 AM, [email protected] wrote:
> Hmm. An external linting problem doesn't fit my application very well.
True. I've used this as a step between build (msi expansion) and load.
> How do you validate field assignments in your application, Michael? I need to be able to do something like the following:
So far only link fields (where I usually typo). Field types are known,
so this could be done for other fields. However, it wouldn't give quite
the same assurance as it would be different code (pypdb doesn't depend
on Base). So I'm not sure if this would be good enough for you.
>>>> a = records.ao('TEST')
>>>> a.DRVL = 'wrong'
> AssertionError: Can't write "test" to field DRVL: not a number
>>>> a.DRVL = 123
>>>> a.SCAN = 'wrong'
> AssertionError: Can't write "wrong" to field SCAN: Not a valid menu choice
>>>> a.SCAN = '.1 second'
> From: Michael Davidsaver [mailto:[email protected]]
>> If you're interested in static validation of db/dbd files, you might
>> have a look at my 'dbdlint' script. This can either validate individual
>> files for basic syntax (--partial), or a full database w/ recordtype
>> defs (--full).
>> This includes a handy (to me) feature to detect unintentional "external"
>> links (aka typos).
>>> $ cat test.db
>>> #: external("other.VAL")
>>> record(longin, "target") {
>>> field(INP, "other")
>>> record(longin, "ok") {
>>> field(INP, "targt") # oops
>>> $ ./dbdlint -F -Wall /path/to/base/dbd/softIoc.dbd test.db
>>> WARNING test.db:8 ext-link - DB/CA Link to outside PV 'targt.VAL'
>> https://github.com/epicsdeb/pypdb/blob/master/documentation/dbdlint.rst
>> https://github.com/epicsdeb/pypdb/blob/master/dbdlint.1.txt
>> On 09/19/2017 01:00 PM, Andrew Johnson wrote:
>>> Hi Michael,
>>> On 09/19/2017 04:34 AM, [email protected] wrote:
>>>> I have just discovered that the dbVerify function has been removed from
>>>> EPICS 3.16. I use the functionality provided by this function to
>>>> validate databases as they are statically constructed (in iocbuilder
>>>> and epicsdbbuilder). At present DLS is still using EPICS 3.14, so I am
>>>> only learning about this from external reports.
- dbVerify removed from EPICS 3.16 michael.abbott
- Re: dbVerify removed from EPICS 3.16 Andrew Johnson
- Re: dbVerify removed from EPICS 3.16 Michael Davidsaver
- RE: dbVerify removed from EPICS 3.16 michael.abbott
Re: Ideas / Suggestions for the future of VME-CPU Operating Systems Michael Davidsaver
Re: PointGrey Firmware Mark Engbretson
<2017>
2025
2026
<2017>
2025
2026
