As Andrew explained, you're likely missing one level of indirection.
Give an MBBI with
field(ONVL, 129)
field(ONST,"Done")
field(THVL,1)
field(THST,"Clearing")
that record will have values 0, 1, 2, 3 represented as ?, Done, ?, Clearing
(didn't see the detail for the ZRVL/ST and TWVL/ST for states 0 and 2)
If you want to map raw value 1 to state 3 (ONVL=1) and raw value 129 to state 1 (ONVL=129), you need to get those raw values into the RVAL field.
For example, you could have an ai record read the 1, 129, ... from your device, and then use INP=that record and DTYP="Raw Soft Channel" for the MBBI.
-Kay
From: [email protected] <[email protected]> on behalf of Andrew Johnson <[email protected]>
Sent: Thursday, September 21, 2017 2:26 PM
To: Iain Marcuson; EPICS Tech Talk
Subject: Re: Enumerated Strings in CSS BOY
Hi Iain,
On 09/21/2017 12:45 PM, Iain Marcuson wrote:
> My software queries a status value from a sensor. I want to display the
> status as a string in my OPI. The status values are neither sequential
> nor zero-indexed. I tried to create an mbbi record with the *VL and *ST
> fields set to match the status string with the status value. CSS BOY,
> however, does not display the string matching the mbbi VAL number, but
> the *ST field corresponding to the VAL number. For example:
> Field(ONVL, 129)
> Field(ONST,"Done")
> Field(THVL,1)
> Field(THST,"Clearing")
> If the mbbi VAL field is 1, then CSS BOY will display "Done" as opposed
> to "Clearing".
> What is the preferred way of outputting a string with such an enum?
The mbbi record type is designed to compare the *VL fields against the
RVAL field, then it sets the VAL field to the index corresponding to the
matching *VL field. The string representation of the VAL field will then
be the string in the corresponding *ST field, and the alarm severity of
the record is set from the corresponding *SV field.
How is this record connecting to your sensor? The device support for an
mbbi should be setting prec->rval (if you're providing your own device
support). If this mbbi is a soft record though (i.e. DSET is unset or
"Soft Channel" then you need to change it to be "Raw Soft Channel" — the
soft support reads an encoded index value from the INP link directly
into VAL and skips the comparisons with the *VL fields, whereas the raw
soft support reads the INP link value into RVAL and goes through the *VL
comparisons.
HTH,
- Andrew
- RE: Enumerated Strings in CSS BOY Iain Marcuson
- Enumerated Strings in CSS BOY Iain Marcuson
- Re: Enumerated Strings in CSS BOY Andrew Johnson
RE: new Scaler driver Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
