1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor module problem
To: Jörn Dreyer <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 28 Sep 2017 11:05:50 +0200
First of all, I don't understand that either.
Which versions (EPICS base, motor) do you use ?
Are you sure that everything is freshly compiled ?
And, could you send us a complete log file ?
On 28/09/17 10:04, Jörn Dreyer wrote:
Hello,
currently I'm working on a piezo motor driver based on the
asynMotorController. At startup of the IOC the Axis::move command is called
with parameters that I do not understand. If I put a printout statement at the
beginning of the function like this:
printf("%s %d %s %f %d %f %f %f\n", "Moving axis", axisNo_+1, "to position",
position, relative, minVelocity, maxVelocity, acceleration);
it results in:
Moving axis 1 to position inf 0 0.000000 0.000000 0.000000
The corresponding record looks like this:
record(motor, "A:m1") {
   field(DESC, "Mirror 1")
   field(DTYP, "asynMotor")
   field(DIR, "1")
   field(VELO, "110.")
   field(VBAS, ".05")
   field(ACCL, ".5")
   field(BDST, "0")
   field(BVEL, "1.0")
   field(BACC, "2")
   field(OUT, "@asyn(B,0)")
   field(MRES, "0.00001")
   field(PREC, "5")
   field(EGU, "mm")
   field(DHLM, "0.32768")
   field(DLLM, "1")
   field(INIT, "")
   field(RTRY, "5")
   field(TWV, "1")
   field(SDIS, "A:m1_able.VAL")
   field(VMAX, "190.")
It gets called three times, first with inf, then with DHLM, and then with
10000. Looks like it wants to do something like homing. How can I prevent
this?
Jörn
Re: Motor module problem Jörn Dreyer
Prev: Motor module problem Jörn Dreyer
Next: Re: Motor module problem Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
