Am Donnerstag, 28. September 2017, 11:05:50 CEST schrieb Torsten Bögershausen:
> First of all, I don't understand that either.
> Which versions (EPICS base, motor) do you use ?
I use EPICS base 3.15.5 and motor R6-9 ans asyn4-32.
> Are you sure that everything is freshly compiled ?
Yes.
> And, could you send us a complete log file ?
Will follow. That's not trivial. I changed the code slightly and now run into
a segmentation fault.
Jörn
> On 28/09/17 10:04, Jörn Dreyer wrote:
> > Hello,
> > currently I'm working on a piezo motor driver based on the
> > asynMotorController. At startup of the IOC the Axis::move command is
> > called
> > with parameters that I do not understand. If I put a printout statement at
> > the beginning of the function like this:
> > printf("%s %d %s %f %d %f %f %f\n", "Moving axis", axisNo_+1, "to
> > position", position, relative, minVelocity, maxVelocity, acceleration);
> > it results in:
> > Moving axis 1 to position inf 0 0.000000 0.000000 0.000000
> > The corresponding record looks like this:
> > record(motor, "A:m1") {
> > field(DESC, "Mirror 1")
> > field(DTYP, "asynMotor")
> > field(DIR, "1")
> > field(VELO, "110.")
> > field(VBAS, ".05")
> > field(ACCL, ".5")
> > field(BDST, "0")
> > field(BVEL, "1.0")
> > field(BACC, "2")
> > field(OUT, "@asyn(B,0)")
> > field(MRES, "0.00001")
> > field(PREC, "5")
> > field(EGU, "mm")
> > field(DHLM, "0.32768")
> > field(DLLM, "1")
> > field(INIT, "")
> > field(RTRY, "5")
> > field(TWV, "1")
> > field(SDIS, "A:m1_able.VAL")
> > field(VMAX, "190.")
> > It gets called three times, first with inf, then with DHLM, and then with
> > 10000. Looks like it wants to do something like homing. How can I prevent
> > this?
> > Regards,
> > Jörn
Dr. Joern Dreyer
HIBEF DAQ + Controls
Institut für Strahlenphysik
Helmholtz-Zentrum Dresden - Rossendorf e.V
Abt. FWKH Tel: +49 351 260 3263
FAX: +49 351 260 3700
01314 Dresden eMail: [email protected]
Bautzner Landstraße 400, 01328 Dresden
Vorstand: Prof. Dr. Roland Sauerbrey, Dr. Dr. h. c. Peter Joehnk
VR 1693 beim Amtsgericht Dresden
- Motor module problem Jörn Dreyer
- Re: Motor module problem Torsten Bögershausen
Question about the epics driver for PXIe-5162 high speed digitizer (National instruments) lzf neu
<2017>
2025
2026
<2017>
2025
2026
