Subject: RE: EPICS areadetecto and EPICSV4
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 10 Oct 2017 12:28:14 +0000
HI Jörn,
I am successfully doing what you are trying to do using RELEASE*.local files that are identical to the EXAMPLE_RELEASE*.local files in the master branch of  areaDetector/configure.
I suspect you did not define the path to the V4 libraries in RELEASE_PATHS.local.  This is the symbol EV4_BASE. My version of that file contains these lines:
# If CONFIG_SITE.local defines WITH_EPICS_V4=YES then define the path here
EV4_BASE     = /corvette/usr/local/epics-devel/epicsV4/EPICS-CPP-4.6.0
RELEASE_LIBS.local contains these lines:
# V4 modules.
PVCOMMON=$(EV4_BASE)/pvCommonCPP
PVACCESS=$(EV4_BASE)/pvAccessCPP
PVDATA=$(EV4_BASE)/pvDataCPP
PVDATABASE=$(EV4_BASE)/pvDatabaseCPP
NORMATIVETYPES=$(EV4_BASE)/normativeTypesCPP
Let me know if you still have problems.
From: [email protected] [[email protected]] on behalf of Jörn Dreyer [[email protected]]
Sent: Tuesday, October 10, 2017 7:14 AM
To: [email protected]
Subject: EPICS areadetecto and EPICSV4
Hi all,
I have a probably stupid question concerning the use of EPICS V4 and the
areadetector code in an IOC.
I'm trying to build an IOC with which I want to readout a GiGE based camera.
To do performance comparisons I also want to include the EPICS V4 code. But If
I enable WITH_EPICS_V4 in the Makefile, I fail to find the  „../../../lib/linux-
x86_64/libpvDatabase.a“ The makefile is searching in the wrong directories. I
included
include $(AREADETECTOR)/ADCore/ADApp/commonDriverMakefile
in my IOC makefile. And therein the EPICS V4 libraries are added to PROD_LIBS.
What variable do I need to set so that make will find those libraries? If I
change PROD_LIBS to PROD_SYS_LIBS, everything compiles fine.
With kind regards,
Jörn Dreyer
Re: EPICS areadetecto and EPICSV4 Ralph Lange
Re: EPICS areadetecto and EPICSV4 Jörn Dreyer
Prev: EPICS areadetecto and EPICSV4 Jörn Dreyer
Next: Re: EPICS areadetecto and EPICSV4 Ralph Lange
