Subject: RE: Building an EPICS App for a Linux Target
To: Nab Rahman <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Oct 2017 22:50:43 +0000
Hi Nab,
For header files that the compiler will find in standard system locations (e.g. /usr/include, etc.) you just need to include types.h in your C or C++ source file.  You don't need to do anything to your Makefile.
For system libraries that will be found in standard locations (/usr/lib, /usr/local/lib, etc) you need to add a line like this to your Makefile (this is for libtiff).
example_SYS_LIBS += tiff
If you have more questions let me know.
From: [email protected] [[email protected]] on behalf of Nab Rahman [[email protected]]
Sent: Thursday, October 19, 2017 2:05 PM
To: [email protected]
Subject: Building an EPICS App for a Linux Target
Hello,
I am currently using EPICS Base 3.14.12.6 with a linux x86_64 machine and am a relatively new user to EPICS.
I want to run an EPICS Application as a Linux target instead of a VxWorks target and was told that the method to do
so was to edit the "App/src/" directory's Makefile but not sure as to how to approach that task.
How does a user add the support libraries needed for certain C code subroutines from their usr/include path?
For example, I need to add the "types.h" header file. I notice there are flag statements (+=) in the makefile as follows:
# Build the main IOC entry point where needed
example_SRCS_DEFAULT += exampleMain.cpp
example_SRCS_vxWorks += -nil-
# Link in the code from our support library
example_LIBS += exampleSupport
I suspect that if I can add the necessary support libraries, then my EPICS app and database will function correctly.
Thanks for the help,
Nab Rahman
Building an EPICS App for a Linux Target Nab Rahman
Prev: MP2000 LVDT Readout/Controller Ibrahim Saleh
Next: Re: Asyn GPIB proto file exception @writetimeout Dirk Zimoch
Prev: Building an EPICS App for a Linux Target Nab Rahman
Next: MP2000 LVDT Readout/Controller Ibrahim Saleh
