1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: s7plc more than one 240-byte PDU
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Fri, 20 Oct 2017 13:28:17 -0400
OK, thanks I'll see what the PLC guys says about that.  That was my first thought, but then I didn't see how on the PLC side to direct the send-block mechanism to an ipaddr:port .
-ps
On Fri, Oct 20, 2017 at 1:24 PM, Zimoch Dirk (PSI) <[email protected]> wrote:
Hello Paul,
If you cannot increase the block size (the driver has no limit on this but maybe the PLC) you can have two blocks on the PLC running on different ports. To the IOC this would look like two devices.
Dirk
Am 20.10.2017 um 19:18 schrieb Paul Sichta <[email protected]>:
I have been using s7plc driver for years with one SND and one RCV block on the PLC.  Now, we need to send more data than can fit in the (max size) 240-byte block.  How can I send more data to EPICS?
-ps
Re: s7plc more than one 240-byte PDU Zimoch Dirk (PSI)
Re: s7plc more than one 240-byte PDU Maurizio Montis
s7plc more than one 240-byte PDU Paul Sichta
Prev: Re: s7plc more than one 240-byte PDU Zimoch Dirk (PSI)
Next: Re: s7plc more than one 240-byte PDU Zimoch Dirk (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
