1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Display of waveform data in CSS
To: Iain Marcuson <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 23 Oct 2017 17:52:44 +0000
Hi:
Try CS-Studio, Utilities, Install Samples to install the "BOY Examples".
Then check out /BOY Examples/widgets/4_6_Array.opi for an example that displays as well as writes arrays.
Should work with an array of 10..20 configuration parameters.
Will likely fail with a 2 million element waveform.
-Kay
From: [email protected] <[email protected]> on behalf of Iain Marcuson <[email protected]>
Sent: Monday, October 23, 2017 1:46 PM
To: EPICS Tech Talk
Subject: Display of waveform data in CSS
I am trying to display and allow editing of a wave
form in CSS of a PV.  I tried the Array Widget as mentioned in
http://www.aps.anl.gov/epics/tech-talk/2012/msg02373.php
When I try to use it, the spinner box gets the correct number of elements in the waveform, as does the scroll bar.  The tooltip shows the correct values in the array.  However, the widget does not show the values, and moving the mouse cursor over the right pane results in the cursor turning into a "No" sign.  Am I using the right widget, and is there a step I am missing?
Iain.
RE: Display of waveform data in CSS Iain Marcuson
Prev: Display of waveform data in CSS Iain Marcuson
Next: RE: Display of waveform data in CSS Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
