That showed it. I didn't realize you had to drag the desired display widget into the Array widget.
Iain.
> -----Original Message-----
> From: Kasemir, Kay [mailto:[email protected]]
> Sent: Monday, October 23, 2017 1:53 PM
> To: Iain Marcuson <[email protected]>; EPICS Tech Talk
> <[email protected]>
> Subject: Re: Display of waveform data in CSS
> Hi:
> Try CS-Studio, Utilities, Install Samples to install the "BOY Examples".
> Then check out /BOY Examples/widgets/4_6_Array.opi for an example that
> displays as well as writes arrays.
> Should work with an array of 10..20 configuration parameters.
> Will likely fail with a 2 million element waveform.
> -Kay
> From: [email protected] <[email protected]> on
> behalf of Iain Marcuson <[email protected]>
> Sent: Monday, October 23, 2017 1:46 PM
> To: EPICS Tech Talk
> Subject: Display of waveform data in CSS
> I am trying to display and allow editing of a wave form in CSS of a PV. I tried
> the Array Widget as mentioned in http://www.aps.anl.gov/epics/tech-
> talk/2012/msg02373.php
> When I try to use it, the spinner box gets the correct number of elements in
> the waveform, as does the scroll bar. The tooltip shows the correct values in
> the array. However, the widget does not show the values, and moving the
> mouse cursor over the right pane results in the cursor turning into a "No"
> sign. Am I using the right widget, and is there a step I am missing?
> Iain.
- Re: Display of waveform data in CSS Kasemir, Kay
- Display of waveform data in CSS Iain Marcuson
<2017>
2025
2026
<2017>
2025
2026
