> I didn't realize you had to drag the desired display widget into the Array widget.
Right, you need to add one 'prototype' widget that's then used to handle each array element.
Use a 'Text Update' for a read-only display, or a 'Text Entry' or some slider widget to edit the array elements.
The example actually shows a more complicated case where the array element is represented by a Group of slider (to write) and text update (to show the number).
It's probably a bad idea to go overboard in that direction, best to just have one plain widget per array element.
-Kay
- Display of waveform data in CSS Iain Marcuson
- Re: Display of waveform data in CSS Kasemir, Kay
- RE: Display of waveform data in CSS Iain Marcuson
Building example IOC app on Windows Flewellen-Gore, Andrew (US)
<2017>
2025
2026
<2017>
2025
2026
