1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building example IOC app on Windows
From: "Flewellen-Gore, Andrew (US)" <[email protected]>
Date: Mon, 23 Oct 2017 21:52:38 +0000
Hello all,
I’m trying to build the example IOC app from the template directory of my EPICS installation. I’m using EPICS 3.16 and mingw32 on a 64 bit Windows machine. I’m pretty sure that my EPICS installation has been built properly but I’d like to test it. Unfortunately I’m having trouble running the Perl script that should build my example IOC application.
c:\example>perl ..\epics\base-3.16.1\bin\win32-x86-mingw\makeBaseApp.pl
-d –b C:\epics\base-3.16.1 -T  C:\epics\base-3.16.1\templates\makeBaseApp\top  -t example example
However, no new files get created in the C:\example directory. It remains empty. Further, specifying –i and –a options yields a similar result (see below), but without the printout claiming some sort of action. I am unsure what the nuance of specifying –i does, but I imagine I need it since I want to run the application on the iocsh, and “boot files” sound important for doing that.
Any help is appreciated, and thanks for reading.
-Andrew
Prev: Re: Display of waveform data in CSS Kasemir, Kay
Next: Re: Epics Motor Record Encoder Sense Stubbs, Scott A.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Problems getting PI motors working Eric Norum
