1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics Motor Record Encoder Sense
To: Žiga Oven <[email protected]>
Date: Mon, 23 Oct 2017 22:21:25 +0000
Hi Wolfgang et al,
This is a pretty common issue.  At LCLS we use a custom version of the motor record that doesn’t support negative ERES, and neither do our ’smart' motors, so we usually have to fix it in hardware as Mark said.  As a rule, if you can make sure to keep the phases consistent from the beginning, that is the way to go and prevents problems down the road.  Just my two cents.
Best regards,
Scott
Scott Stubbs
LCLS Controls & Data Systems
[email protected]
On 23 Oct 2017, at 9:09 am, Žiga Oven <[email protected]> wrote:
Hallo,
I am new in epics motor record control and try to configure my first axis with encoder. I am now in trouble with an linear axis with encoder Pro (dex Maxnet Controller). Without encoder. the axis works fine. I activated encoder read out by adding PSE to the init string, UEIP to yes and ERES to 5e-5, then the RBV field changes negative by the correct absolute value, when I move positive with TWF .1. I tried to set ERES negative to -5e-5 without any effect. Has somebody an idea how to change the sense of the encoder readout?
Thank you very much
   Wolfgang
Epics Motor Record Encoder Sense Mexner, Wolfgang (IBPT)
RE: Epics Motor Record Encoder Sense Mark Rivers
Re: Epics Motor Record Encoder Sense Žiga Oven
Prev: Building example IOC app on Windows Flewellen-Gore, Andrew (US)
Next: Problems getting PI motors working Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Epics Motor Record Encoder Sense Žiga Oven
Next: Re: Epics Motor Record Encoder Sense Pearson, Matthew R.
