1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics Motor Record Encoder Sense
To: "'Mexner, Wolfgang (IBPT)'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 23 Oct 2017 09:09:45 -0700
Hi Wolfgang,
You could also use the command EDI that inverts encoder direction on OMS Pro-dex MAXnet.
MAXnet Command Reference Manual (Rev G), page  105, section 2-97)
Best regards,
Žiga
On 23.10.2017 8:23, Mark Rivers wrote:
I'm not sure, but I think you may need to do this in hardware, i.e. swap either the motor phases or the encoder phases.
From: [email protected] [mailto:[email protected]] On Behalf Of Mexner, Wolfgang (IBPT)
Sent: Monday, October 23, 2017 10:15 AM
To: [email protected]
Subject: Epics Motor Record Encoder Sense
Hallo,
I am new in epics motor record control and try to configure my first axis with encoder. I am now in trouble with an linear axis with encoder Pro (dex Maxnet Controller). Without encoder. the axis works fine. I activated encoder read out by adding PSE to the init string, UEIP to yes and ERES to 5e-5, then the RBV field changes negative by the correct absolute value, when I move positive with TWF .1. I tried to set ERES negative to -5e-5 without any effect. Has somebody an idea how to change the sense of the encoder readout?
Thank you very much
    Wolfgang
Re: Epics Motor Record Encoder Sense Stubbs, Scott A.
Epics Motor Record Encoder Sense Mexner, Wolfgang (IBPT)
RE: Epics Motor Record Encoder Sense Mark Rivers
Prev: Re: Epics Motor Record Encoder Sense Pearson, Matthew R.
Next: Display of waveform data in CSS Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Epics Motor Record Encoder Sense Mark Rivers
Next: Re: Epics Motor Record Encoder Sense Stubbs, Scott A.
