Subject: Re: How to use Archiver Appliance to archive PVs of only the latest period of time
To: "Shankar, Murali" <[email protected]>
Date: Mon, 30 Oct 2017 18:30:49 +0800 (GMT+08:00)
Hello Murali,
Sorry for following up this thread so late.
> You could then delete the older data using a Python script.
But how should I delete the older data using a Python script? Should I use a Python script to directly operate the .pb files in the file system, or to interact with the Archiver Appliance BPL Servlet/HTTP interface?
Lin
-----Original Messages-----
Sent Time:2017-09-14 12:04:32 (Thursday)
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Cc:
Hi Lin,
>> In order to save storage space, we just want to archive PVs of the latest one month.
You should be able to create a policy for these 5000 PV's with a partition granularity of a month. That is, in your policies.py file, your LTS (or MTS) can be something like
pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&partitionGranularity=PARTITION_MONTH.
If you add PV's to the archiver using this policy, you should be able to store data in chunks of one month each.
>> the requirement may be adjusted to three or six months in future)
You could then delete the older data using a Python script. Or, if you decided to keep, let's say four months you could add a blackhole plugin after this plugin. For example,
LTS -> partitionGranularity=PARTITION_MONTH​&hold=5&gather=1 followed by a
Final -> 'blackhole://localhost'
would keep at least (5-1)=4 months data in your LTS.
For more details, please see http://slacmshankar.github.io/epicsarchiver_docs/api/edu/stanford/slac/archiverappliance/PlainPB/PlainPBStoragePlugin.html​
Hope that helps.
Murali
Re: How to use Archiver Appliance to archive PVs of only the latest period of time Shankar, Murali
Prev: streamdevice and AD driver in same IOC Hinko Kocevar
Next: Re: How to define a global variable and global array in python script for a widget of Control system studio (CS Kasemir, Kay
Prev: Re: How to use Archiver Appliance to archive PVs of only the latest period of time Shankar, Murali
Next: Re: How to use Archiver Appliance to archive PVs of only the latest period of time Shankar, Murali
