Subject: Re: How to define a global variable and global array in python script for a widget of Control system studio (CS
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 30 Oct 2017 12:49:17 +0000
Hi:
This is how you read:
> data="">
This is _not_ how you write, since you obviously can't assign anything to the number returned by getDouble():
> PVUtil.getDouble(pvs[1])=data
> However, the error occurs:
> SyntaxError:("can't assign to function call", ('<script>',3,0, 'PVUtil.getDouble(pvs[0])=value\n'))
This is how you would write:
pvs[1].setValue(data)
If you want to use scripts, it might be a good idea to study the example scripts in BOY Examples/scripts, where "setValue" is used a couple of times.
Or read the online help:
CSS Applications, Displays, BOY, Script, Access PV, "2. Write PV Value" introduces PV.setValue.
-Kay
Re: How to define a global variable and global array in python script for a widget of Control system studio (CSS) ? Anton Derbenev
答复: How to define a global variable and global array in python script for a widget of Control system studio (CSS) ? lzf neu
Prev: Re: How to use Archiver Appliance to archive PVs of only the latest period of time Wang, Lin
Next: Re: streamdevice and AD driver in same IOC Mark Rivers
Prev: 答复: How to define a global variable and global array in python script for a widget of Control system studio (CSS) ? lzf neu
Next: Optimum Switch Over Time of Master and Slave IOC Michaelsmith2017
