Subject: |
issue with either camonitor or pcaspy in 3.15? |
Jameson Graef Rollins <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Thu, 02 Nov 2017 14:14:56 -0700 |
Hi, all. I'm noticing a strange behavior when using the camonitor
command line tool in EPICS 3.15. I'm seeing a behavior change between
3.15 and 3.14.
I have a test pcaspy IOC running that is serving four channels. (As an
aside, I am also slightly suspicious that the problem could be in
pcaspy, but I'm not sure). I launch the IOC, so it has so far seen no
client connections. I then connect with camonitor:
$ camonitor T1:TEST-{A,B,C,D}
T1:TEST-A 2017-11-02 13:57:42.126037 0
T1:TEST-B 2017-11-02 13:57:42.126067 0
T1:TEST-C 2017-11-02 13:57:42.126055 0
T1:TEST-D 2017-11-02 13:57:42.126082 0
So far so good. I then use caput to change one the values, but
camonitor outputs something for all channels it's monitoring, even the
ones that haven't changed:
T1:TEST-A 2017-11-02 13:57:50.067417 1
Note that this here is specifically what I see as the problem: camonitor
is reporting changes on channels that have no changes. This is
different behavior than I was seeing in 3.14.
If I think do another put, I only see the one channel change:
T1:TEST-A 2017-11-02 13:57:55.484140 2
If I kill camonitor and reconnect things seem to work as expected:
T1:TEST-A 2017-11-02 14:06:30.586715 2
T1:TEST-B 2017-11-02 14:02:11.625264 0
T1:TEST-C 2017-11-02 14:02:11.625251 0
T1:TEST-D 2017-11-02 14:02:11.625278 0
When I do a put only the one channel changes:
T1:TEST-A 2017-11-02 14:06:47.025503 3
I don't see this behavior with the pyepics epics.camonitor function.
That would seem to point to it being an issue with camonitor cli.
However the fact that things behave as expected on subsequent
connections makes me think it might be pcaspy startup issue.
Any ideas?
jamie.
signature.asc
Description: PGP signature
- Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
Re: concurrent put callbacks Pearson, Matthew R.
RE: concurrent put callbacks Andrew C. Starritt
<2017>
2025
2026
<2017>
2025
2026
