Subject: areaDetector and HDF5 file saving segafaults
Date: Tue, 7 Nov 2017 10:58:03 +0100
I'm experiencing segmentation faults that trace to HDF5 file saving plugin. This is with ADAravis camera, 10 images per second.
EPICS base is 3.15.4, AreaDetector is 3-1.
epics>
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffed55a700 (LWP 27283)]
0x00007ffff35d7d89 in __memcpy_ssse3_back () from /lib64/libc.so.6
(gdb) bt
#0  0x00007ffff35d7d89 in __memcpy_ssse3_back () at /lib64/libc.so.6
#1  0x00007ffff6371211 in H5Pset_fill_value (plist_id=<optimized out>, type_id=216172782117023038, value=0x7ffd67ff2fb0) at ../H5Pdcpl.c:3217
#2  0x00007ffff776bff7 in NDFileHDF5AttributeDataset::createHDF5Dataset() (this=this@entry=0x7ffd5c007460) at ../NDFileHDF5AttributeDataset.cpp:99
#3  0x00007ffff776c648 in NDFileHDF5AttributeDataset::createDataset(int) (this=this@entry=0x7ffd5c007460, user_chunking=<optimized out>)
    at ../NDFileHDF5AttributeDataset.cpp:75
#4  0x00007ffff776529e in NDFileHDF5::createAttributeDataset(NDArray*) (this=this@entry=0x939530, pArray=pArray@entry=0x7fff10968800)
    at ../NDFileHDF5.cpp:2535
#5  0x00007ffff776717f in NDFileHDF5::openFile(char const*, int, NDArray*) (this=0x939530, fileName=0x7fffed5595d0 "/home/dev/DTUdata/image1_20896.h5", openMode=<optimized out>, pArray=0x7fff10968800) at ../NDFileHDF5.cpp:268
#6  0x00007ffff775820d in NDPluginFile::openFileBase(int, NDArray*) (this=this@entry=0x939530, openMode=openMode@entry=2, pArray=pArray@entry=0x7fff10968800) at ../NDPluginFile.cpp:73
#7  0x00007ffff7758ee4 in NDPluginFile::writeFileBase() (this=this@entry=0x939530) at ../NDPluginFile.cpp:230
#8  0x00007ffff77597f8 in NDPluginFile::processCallbacks(NDArray*) (this=0x939530, pArray=0x7fff10968800) at ../NDPluginFile.cpp:751
#9  0x00007ffff770871e in NDPluginDriver::processTask() (this=0x939530) at ../NDPluginDriver.cpp:467
#10 0x00007ffff48d44c9 in epicsThreadCallEntryPoint(void*) (pPvt=0x7fffd4001400) at ../../../src/libCom/osi/epicsThread.cpp:85
#11 0x00007ffff48d9f6c in start_routine (arg=0x7fffd4001310) at ../../../src/libCom/osi/os/posix/osdThread.c:403
#12 0x00007ffff2f66e25 in start_thread () at /lib64/libpthread.so.0
#13 0x00007ffff358534d in clone () at /lib64/libc.so.6
Hinko
.. the more I see the less I believe.., AE AoR
Re: areaDetector and HDF5 file saving segafaults Mark Rivers
Prev: Re: A Problem : run it on the target board. Michael Davidsaver
Next: Re: areaDetector and HDF5 file saving segafaults Mark Rivers
Prev: Re: A Problem : run it on the target board. Seung-hee Nam
