Subject: Re: areaDetector and HDF5 file saving segafaults
To: Hinko Kocevar <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Nov 2017 13:59:44 +0000
Hi Hinko,
Also, what version of HDF5 are you using, the one from ADSupport (and if so what version) or a system library version?
From: [email protected] <[email protected]> on behalf of Hinko Kocevar <[email protected]>
Sent: Tuesday, November 7, 2017 3:58 AM
To: [email protected]
Subject: areaDetector and HDF5 file saving segafaults
I'm experiencing segmentation faults that trace to HDF5 file saving plugin. This is with ADAravis camera, 10 images per second.
EPICS base is 3.15.4, AreaDetector is 3-1.
epics>
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffed55a700 (LWP 27283)]
0x00007ffff35d7d89 in __memcpy_ssse3_back () from /lib64/libc.so.6
(gdb) bt
#0  0x00007ffff35d7d89 in __memcpy_ssse3_back () at /lib64/libc.so.6
#1  0x00007ffff6371211 in H5Pset_fill_value (plist_id=<optimized out>, type_id=216172782117023038, value=0x7ffd67ff2fb0) at ../H5Pdcpl.c:3217
#2  0x00007ffff776bff7 in NDFileHDF5AttributeDataset::createHDF5Dataset() (this=this@entry=0x7ffd5c007460) at ../NDFileHDF5AttributeDataset.cpp:99
#3  0x00007ffff776c648 in NDFileHDF5AttributeDataset::createDataset(int) (this=this@entry=0x7ffd5c007460, user_chunking=<optimized out>)
    at ../NDFileHDF5AttributeDataset.cpp:75
#4  0x00007ffff776529e in NDFileHDF5::createAttributeDataset(NDArray*) (this=this@entry=0x939530, pArray=pArray@entry=0x7fff10968800)
    at ../NDFileHDF5.cpp:2535
#5  0x00007ffff776717f in NDFileHDF5::openFile(char const*, int, NDArray*) (this=0x939530, fileName=0x7fffed5595d0 "/home/dev/DTUdata/image1_20896.h5", openMode=<optimized out>, pArray=0x7fff10968800) at ../NDFileHDF5.cpp:268
#6  0x00007ffff775820d in NDPluginFile::openFileBase(int, NDArray*) (this=this@entry=0x939530, openMode=openMode@entry=2, pArray=pArray@entry=0x7fff10968800) at ../NDPluginFile.cpp:73
#7  0x00007ffff7758ee4 in NDPluginFile::writeFileBase() (this=this@entry=0x939530) at ../NDPluginFile.cpp:230
#8  0x00007ffff77597f8 in NDPluginFile::processCallbacks(NDArray*) (this=0x939530, pArray=0x7fff10968800) at ../NDPluginFile.cpp:751
#9  0x00007ffff770871e in NDPluginDriver::processTask() (this=0x939530) at ../NDPluginDriver.cpp:467
#10 0x00007ffff48d44c9 in epicsThreadCallEntryPoint(void*) (pPvt=0x7fffd4001400) at ../../../src/libCom/osi/epicsThread.cpp:85
#11 0x00007ffff48d9f6c in start_routine (arg=0x7fffd4001310) at ../../../src/libCom/osi/os/posix/osdThread.c:403
#12 0x00007ffff2f66e25 in start_thread () at /lib64/libpthread.so.0
#13 0x00007ffff358534d in clone () at /lib64/libc.so.6
Hinko
.. the more I see the less I believe.., AE AoR
Re: areaDetector and HDF5 file saving segafaults Hinko Kocevar
Prev: Re: areaDetector and HDF5 file saving segafaults Mark Rivers
Next: caLab and real time os Pierrick Hanlet
Next: Re: areaDetector and HDF5 file saving segafaults Hinko Kocevar
