Subject: Re: caLab and real time os
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Nov 2017 13:13:18 +0000
Hi Pierrick,
we have a LabVIEW based sub-system (running NI real time OS, like you) using "official" NI EPICS support described here:
http://www.ni.com/white-paper/14144/en/
The drawback is that the published PV are missing some properties (e.g. EGU). We solved the issue by adding a softIoc with a DB with a fully qualified PV populated by the value retrieved by the LabVIEW PV using this pattern (and the other way round):
As suggested by Mark Rivers in this thread:
http://www.aps.anl.gov/epics/tech-talk/2016/msg01926.php
Luca
On Wed, 2017-11-08 at 07:03 +0000, Pierrick Hanlet wrote:
Thank you Carsten,
Can you recommend some options?
Best wishes,
Pierrick
On 11/08/2017 05:53 AM, Carsten Winkler wrote:
Hello Pierrick,
your LabVIEW expert is right. CaLab has native libraries which are not suitable for real time OS.
Best regards
Carsten Winkler (developer of CaLab)
Pierrick Hanlet <pierrick.hanlet@tokamakenergy.co.uk> schrieb am 07.11.2017:
Dear tech-talk,
Can someone clarify if there is a caLab library that can be used to build a labview vi
for a real time OS?  My labview expert has read somewhere that caLab is not
compatible.
Thank you,
Pierrick
-- Diese Nachricht wurde mit K-@ Mail gesendet.
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
caLab and real time os Pierrick Hanlet
Re: caLab and real time os Carsten Winkler
Re: caLab and real time os Pierrick Hanlet
Prev: RE: caLab and real time os freddie.akeroyd
Next: motor module compile problems Jörn Dreyer
Next: RE: caLab and real time os Baily, Scott A
