Subject: motor module compile problems
Date: Wed, 08 Nov 2017 15:12:50 +0100
I have had some trouble compiling the motor module (from git) on a openSuSE
Tumbleweed system with gcc 7.2.1. It fails in all motor drivers at the calls
of send_message where the last parameter is passed as (char) NULL. But in the
definition of send_message the last parameter is defined as char*.
What would be the correct fix for this? One could
1. modify all calls to send_message(..,..,(char) NULL) to
send_message(..,..,(char*) NULL), or
2. modify the definition of send_message(..,..,char*)to
send_message(..,..,char), but then other calls may fail.
I chose  the first solution to get it compiled.  If needed I can send a patch
file to correct all necessary lines.
Jörn
RE: motor module compile problems Mark Rivers
Prev: Re: caLab and real time os Luca Cavalli
Next: RE: motor module compile problems Mark Rivers
Prev: RE: caLab and real time os Mazanec Tomáš
