Subject: EPICS base R3.15.5-1.0 special CONFIG and RULE files
To: "'[email protected]'" <[email protected]>
Date: Thu, 9 Nov 2017 19:26:54 +0000
I'm upgrading an EPICS IOC Application from R3.14.12 to R3.15.5-1.0 and I'm using the new schema of adding  configure/CONFIG_ALARMS file and including this file in the configure/Makefile.  This does indeed install alhConfig files into the directory $TOP/alh. However, it method does not generate alhConfig files from an alhsubstitutions file, without  adding configure/RULES.Alarms file.   I was told that I don't need a special RULES file anymore with this new version of EPICS.  Am I missing something?
- Kristi
Re: EPICS base R3.15.5-1.0 special CONFIG and RULE files Andrew Johnson
Prev: Re: areaDetector and HDF5 file saving segafaults Mark Rivers
Next: Re: caget() from C++ Andrew Johnson
Prev: Re: caget() from C++ Mark Rivers
Next: Re: EPICS base R3.15.5-1.0 special CONFIG and RULE files Andrew Johnson
