Subject: Re: EPICS base R3.15.5-1.0 special CONFIG and RULE files
To: "Luchini, Kristi L." <[email protected]>, "'[email protected]'" <[email protected]>
Date: Thu, 9 Nov 2017 15:32:50 -0600
Hi Kristi,
On 11/09/2017 01:26 PM, Luchini, Kristi L. wrote:
> I'm upgrading an EPICS IOC Application from R3.14.12 to R3.15.5-1.0
> and I'm using the new schema of adding  configure/CONFIG_ALARMS file
> and including this file in the configure/Makefile.  This does indeed
> install alhConfig files into the directory $TOP/alh. However, it
> method does not generate alhConfig files from an alhsubstitutions
> file, without  adding configure/RULES.Alarms file.   I was told that
> I don't need a special RULES file anymore with this new version of
> EPICS.  Am I missing something?
Did you mean to send this message to tech-talk, because I don't think
anyone outside of SLAC can help you with what I presume to be a local
feature of your installation. The "-1.0" on the end of your Base version
number is another indicator that you have local customizations which the
rest of us probably won't know anything about.
- Andrew
EPICS base R3.15.5-1.0 special CONFIG and RULE files Luchini, Kristi L.
Prev: How to turn off spewing messaging from asyn/stream devicse. Luchini, Kristi L.
Next: RE: How to turn off spewing messaging from asyn/stream devicse. Mark Rivers
Prev: EPICS base R3.15.5-1.0 special CONFIG and RULE files Luchini, Kristi L.
Next: How to turn off spewing messaging from asyn/stream devicse. Luchini, Kristi L.
