Hi Mark, Thanks for your answer. You give a good summary of the whole communication process. I was asking about the communication paradigm as an attempt to determine in which level of abstraction EPICS works. For example the Message Passing Paradigm is associated with the lowest level of abstraction in distributed inter-process communications. Message Systems Paradigm (aka Message Oriented Middleware) works in a higher level of abstraction than Message Passing, but lower than Distributed Object Paradigm. EPICS use the Channel Access Protocol to communicate clients and servers, but I couldn't intuitively map this protocol to any of the "common" communication paradigms I know (besides the Distributed Objects Paradigm). On Sat, Nov 11, 2017 at 6:59 PM, Mark Rivers <[email protected]> wrote: Hi Renato, Renato Sanhueza Ulsen
Ing Civil Informática.
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
