1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compile error with areaDetector
Date: Wed, 15 Nov 2017 13:58:13 +0100
Hi Mark,
I'm using:
 $gcc --version
gcc (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.5 LTS
Release:        14.04
Codename:       trusty
Jörn
> Hi Jörn,
> I don't have experience with gcc 5.4.0.  But you say you are also getting an
> error with gcc 4.8.  I am running gcc 4.8.5
> gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16)
> and ntndArrayConverter.cpp compiles fine for me with that compiler.  Exactly
> which version of gcc 4.8 is failing for you?
> Mark
> ________________________________
> From: [email protected] <[email protected]> on
> behalf of Dreyer, Dr. Joern <[email protected]> Sent: Wednesday, November
> 15, 2017 1:26 AM
> To: [email protected]
> Subject: Compile error with areaDetector
> Hi,
> I have run into a problem with areaDetector compilation when enabling EPICS4
> using version 4.6.0 on Ubuntu16.04.3 LTS.
> ../ntndArrayConverter.cpp: In member function ‘void
> NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’:
> ../ntndArrayConverter.cpp:497:54: error: no matching function for call to
> ‘std::tr1::shared_ptr<epics::pvData::PVField>::reset() const’
>    dest->getSubField<PVUnion>("value")->get().reset();
> In file included from /usr/include/c++/5/tr1/memory:50:0,
>    from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/share
> dPtr.h:124, from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvTyp
> e.h:41, from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvDis
> play.h:14, from
> /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/normativeTypesCPP/include/
> pv/ntndarray.h:17, from ../ntndArrayConverter.h:2,
>    from ../ntndArrayConverter.cpp:4:
> /usr/include/c++/5/tr1/shared_ptr.h:644:7: note: candidate: void
> std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
> (__gnu_cxx::_Lock_policy)2u] <near match>
>    reset() // never throws
> /usr/include/c++/5/tr1/shared_ptr.h:644:7: note:  passing ‘const PVFieldPtr*
> {aka const std::tr1::shared_ptr<epics::pvData::PVField>*}’ as ‘this’
> argument discards qualifiers
> /usr/include/c++/5/tr1/shared_ptr.h:649:9: note: candidate: template<class
> _Tp1> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*) [with _Tp1 = _Tp1;
> _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
>    reset(_Tp1* __p) // _Tp1 must be complete.
> /usr/include/c++/5/tr1/shared_ptr.h:649:9: note:  template argument
> deduction/substitution failed:
> ../ntndArrayConverter.cpp:497:54: note:  candidate expects 1 argument, 0
> provided
>    from
> dPtr.h:124, from
> e.h:41, from
> play.h:14, from
> /usr/include/c++/5/tr1/shared_ptr.h:658:9: note: candidate: template<class
> _Tp1, class _Deleter> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*,
> _Deleter) [with _Tp1 = _Tp1; _Deleter = _Deleter; _Tp =
>    reset(_Tp1* __p, _Deleter __d)
> /usr/include/c++/5/tr1/shared_ptr.h:658:9: note:  template argument
> ../ntndArrayConverter.cpp:497:54: note:  candidate expects 2 arguments, 0
> provided
> The used gcc version is 5.4.0. On Ubuntu 14.04.5 LTS The error comes at the
> same line, but different problem:
> ../ntndArrayConverter.cpp:497:54: error: passing ‘const PVFieldPtr {aka
> const std::tr1::shared_ptr<epics::pvData::PVField>}’ as ‘this’ argument of
> ‘void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> (__gnu_cxx::_Lock_policy)2u]’ discards qualifiers [-fpermissive]
> here the used gcc version is 4.8. It look like an explicit typecast is
> necessary here. But what would be the correct type?
> Regards,
> Jörn
Re: Compile error with areaDetector Mark Rivers
Compile error with areaDetector Dreyer, Dr. Joern
Prev: Re: Problem when formating a field as HEX32 Mark Rivers
Next: Re: Problem when formating a field as HEX32 Pilar Gil Jaldo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Compile error with areaDetector Mark Rivers
Next: Re: Compile error with areaDetector Mark Rivers
