1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem when formating a field as HEX32
To: Mark Rivers <[email protected]>, 'Pilar Gil Jaldo' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 Nov 2017 16:50:09 +0000
> I think you are probably correct that it is an issue with CSS.
Right.
In separate communication Pilar tried changing the BOY 'Connection Layer' preference from pvmanager to utility_pv or vtype_pv, which are both fine.
Only with pvmanager does he see the value modifications.
-Kay
Problem when formating a field as HEX32 Pilar Gil Jaldo
RE: Problem when formating a field as HEX32 Mark Rivers
Re: Problem when formating a field as HEX32 Pilar Gil Jaldo
Re: Problem when formating a field as HEX32 Mark Rivers
Prev: RE: Problem when formating a field as HEX32 Mark Rivers
Next: EPICS Qt release 3.5.2 Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: AKTA pure James Rezende Piton
