1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: issue with either camonitor or pcaspy in 3.15?
To: Wang Xiaoqiang <[email protected]>, EPICS tech-talk <[email protected]>
Date: Sat, 18 Nov 2017 18:47:26 -0800
On Fri, Nov 03 2017, Wang Xiaoqiang <[email protected]> wrote:
> Here is my test on linux-x86_64 arch, using pcaspy 0.7.0 anaconda
> package from https://anaconda.org/paulscherrerinstitute/pcaspy
> It does not reproduce the problem. Any chance that you could test using
> the same setup?
Hi, Xiaoqiang.  Thanks for confirming for me.  I finally figured out
what the issue was.  In my test pcaspy IOC, on init I am attempting to
clear the "UDF INVALID" flags with the following:
     for k in pvdb:
         driver.setParamStatus(k, pcaspy.Severity.NO_ALARM, pcaspy.Severity.NO_ALARM)
In earlier pcaspy versions this was sufficient to clear the flags
without causing any additional odd behavior.  I see now that with 0.6
and later the issue I need to additionally call updatePVs() after the
above:
     driver.updatePVs()
Is this the right thing to do?  Is there a cleaner way to clear the
initial "UDF INVALID" flags?  And why is the "UDF INVALID" set
initially anyway?
Thanks so much for the help.
jamie.
Attachment: signature.asc
Description: PGP signature
Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
Prev: Re: areaDetector and HDF5 file saving segafaults Mark Rivers
Next: Illunis CMV-50 camera & Kaya Custom Fiber framegrabber neil.o'brien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
Next: Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
