Subject: dbGetLink question
Date: Fri, 1 Dec 2017 14:47:22 +0000
Folks,
I have a question about how dbGetLink works.  I have read the Application Developer's Guide (3.15.5) but it is not clear.  Specifically I want to understand how it works under the following conditions:
- Link is an output link
- Link process type is CA
- The output PV resides in another IOC.
Does dbGetLink actually read the value from the other IOC?  It seems like that would be a slow operation, and so would require the record to be asynchronous?  Or does the database put a camonitor on that external record so the link value can be obtained without an actual caget operation?  If so, I cannot find this mentioned in the Application Developer's Guide.  It only describes channel access monitors being set up for input links, not output links.
Re: dbGetLink question Andrew Johnson
Prev: RE: Channel access blocking Mark Engbretson
Next: Re: Channel access blocking Mark Rivers
Prev: Re: Channel access blocking Williams Jr., Ernest L.
Next: Re: dbGetLink question Andrew Johnson
