Subject: Re: Channel access blocking
From: "Williams Jr., Ernest L." <[email protected]>
To: Mark Rivers <[email protected]>, Mark Engbretson <[email protected]>, "'Hidas, Dean'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 1 Dec 2017 14:58:30 +0000
The support for this is available as of EPICS 3.15.4 on the ca server.
Please see:
http://www.aps.anl.gov/epics/base/R7-0/1-docs/RELEASE_NOTES.html
Cheers,
Ernest Williams
Dept. Head, Advanced Control Systems
Advanced Instrumentation Research, Technology Innovation Directorate
SLAC National Laboratory, Stanford University
From: [email protected] <[email protected]> on behalf of Mark Rivers <[email protected]>
Sent: Friday, December 1, 2017 6:53 AM
To: Mark Engbretson; 'Hidas, Dean'; [email protected]
> You could use
> EPICS_CA_ADDR_LIST
That only works for CA clients.  The IOC server will still serve the PVs on all interfaces.
There is another environment variable that applies to CA servers.  This is from the 3-14 Channel Access Reference Manual.
Binding a Server to a Limited Set of Network Interfaces
The parameter EPICS_CAS_INTF_ADDR_LIST allows a ca server to bind itself to, and therefore accept messages only over, a limited set of the local host's network interfaces (each specified by it's IP address). On UNIX systems type "netstat -i" (type "ipconfig" on windows) to see a list of the local host's network interfaces. Specifically, UDP search messages addressed to both the IP addresses in EPICS_CAS_INTF_ADDR_LIST and also to the broadcast addresses of the corresponding LAN interfaces will be accepted by the server. By default, the CA server is accessible from all network interfaces configured into its host. In R3.14 and previous releases the CA server employed by iocCore does not implemet this feature.
Note that in 3.14 this does not work for the IOC server.  I am not sure if it is implemented in 3.15. or 3.16?
Indeed, it has been implemented:
Please see:
From: [email protected] <[email protected]> on behalf of Mark Engbretson <[email protected]>
Sent: Friday, December 1, 2017 8:42 AM
To: 'Hidas, Dean'; [email protected]
Subject: RE: Channel access blocking
You could use
EPICS_CA_ADDR_LIST
And set it to the broadcast address(s) of the interface(s) that you want to
use and set
EPICS_CA_AUTO_ADDR_LIST=NO
So that EPICS will not try to use ever Ethernet adapter that it detects.
-----Original Message-----
On Behalf Of Hidas, Dean
Sent: Friday, December 1, 2017 7:27 AM
To: [email protected]
Subject: Channel access blocking
I'm using EPICS R3.14.12.3-8.  I have a (many) PC with 2 ethernet ports
connected to different networks.  Is there a simple way to completely block
channel access from 1 of them? ie, make all PVs, beacons, etc unavailable to
that interface?
Thanks for your help,
-Dean Hidas=
Channel access blocking Hidas, Dean
RE: Channel access blocking Mark Engbretson
Re: Channel access blocking Mark Rivers
Prev: Re: Channel access blocking Mark Rivers
Next: Re: dbGetLink question Andrew Johnson
Next: dbGetLink question Mark Rivers
