Hi Mark,
It is on Linux. ADAndor is master branch from github. It worked before, with another ADAndor version, and AD 2-6.
Come to think of it, I might not be using the same compile vs. Runtime Andor support libs.. Need to double check that one.
Thanks, Hinko Also, how is your spectrograph connected to the computer? Is it directly connected via USB or indirectly via the connector labeled "Camera". The latter is how mine is connected.
> -----Original Message-----
> From: Mark Rivers
> Sent: Friday, December 01, 2017 10:51 AM
> To: 'Hinko Kocevar'; [email protected]
> Subject: RE: Andor shamrock not detected
> Hi Hinko,
> Is this Linux or Windows?
> What version of ADAndor?
> Did it ever work, or is this the first time you have tried it.
> I do recall some people at the APS having trouble with the Shamrock under Linux, but I
> think they did get it working. It is working fine for me under Windows.
> Mark
> > From: [email protected] [mailto:[email protected]] On Behalf
> > Of Hinko Kocevar
> > Sent: Friday, December 01, 2017 10:31 AM
> > To: [email protected]
> > Subject: Andor shamrock not detected
> > Hi,
> > I have trouble talking to Andor shamrock spectrograph.
> > It fails after calling Andor API:
> > error = ShamrockGetNumberDevices(&numDevices);
> > because numDevices evaluates to < 1.
> > If I try with Andor supplied C example it works fine, I can control
> > the spectrograph.
> > Here is what the example does for initialization - and it does not
> > look any different, AFAICT, from what EPICS AD Andor support does:
> > //Initialize CCD
> > error = Initialize("/usr/local/etc/andor-2.102.30001.0");
> > if(error!=DRV_SUCCESS){
> > cout << "Initialisation error: " << error << "
> > ...exiting" <<endl;
> > return(1);
> > cout << "Camera ready!" << endl;
> > //Initialize Shamrock CCD
> > error = ShamrockInitialize("");
> > if(error!=SHAMROCK_SUCCESS){
> > ...exiting" <<endl;
> > ShutDown();
> > return(1);
> > cout << "Shamrock ready!" << endl;
> > int nodevices(0);
> > ShamrockGetNumberDevices(&nodevices);
> > if(nodevices < 1) {
> > cout << "No Shamrock detected...exiting" <<endl;
> > ShamrockClose();
> > ShutDown();
> > return(1);
> > Han anyone had similar issues?
> > Thanks,
> > Hinko
.. the more I see the less I believe.., AE AoR
- Re: Andor shamrock not detected Hinko Kocevar
- Andor shamrock not detected Hinko Kocevar
- RE: Andor shamrock not detected Mark Rivers
Re: dbGetLink question Andrew Johnson
EPICS 7 Release Candidate 1 Andrew Johnson
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
