FYI, solved. It was the Andor support library that made the difference.
Hinko
On Fri, Dec 1, 2017 at 8:06 PM, Hinko Kocevar <[email protected]> wrote:
> Hi Mark,
> It is on Linux. ADAndor is master branch from github. It worked before, with
> another ADAndor version, and AD 2-6.
> Come to think of it, I might not be using the same compile vs. Runtime Andor
> support libs.. Need to double check that one.
> Thanks,
> Hinko
> On Fri, 1 Dec 2017 at 18:04, Mark Rivers <[email protected]> wrote:
>> Also, how is your spectrograph connected to the computer? Is it directly
>> connected via USB or indirectly via the connector labeled "Camera". The
>> latter is how mine is connected.
>> Mark
>> > -----Original Message-----
>> > From: Mark Rivers
>> > Sent: Friday, December 01, 2017 10:51 AM
>> > To: 'Hinko Kocevar'; [email protected]
>> > Subject: RE: Andor shamrock not detected
>> > Hi Hinko,
>> > Is this Linux or Windows?
>> > What version of ADAndor?
>> > Did it ever work, or is this the first time you have tried it.
>> > I do recall some people at the APS having trouble with the Shamrock
>> > under Linux, but I
>> > think they did get it working. It is working fine for me under Windows.
>> > Mark
>> > > From: [email protected]
>> > > [mailto:[email protected]] On Behalf
>> > > Of Hinko Kocevar
>> > > Sent: Friday, December 01, 2017 10:31 AM
>> > > To: [email protected]
>> > > Subject: Andor shamrock not detected
>> > > Hi,
>> > > I have trouble talking to Andor shamrock spectrograph.
>> > > It fails after calling Andor API:
>> > > error = ShamrockGetNumberDevices(&numDevices);
>> > > because numDevices evaluates to < 1.
>> > > If I try with Andor supplied C example it works fine, I can control
>> > > the spectrograph.
>> > > Here is what the example does for initialization - and it does not
>> > > look any different, AFAICT, from what EPICS AD Andor support does:
>> > > //Initialize CCD
>> > > error = Initialize("/usr/local/etc/andor-2.102.30001.0");
>> > > if(error!=DRV_SUCCESS){
>> > > cout << "Initialisation error: " << error << "
>> > > ...exiting" <<endl;
>> > > return(1);
>> > > cout << "Camera ready!" << endl;
>> > > //Initialize Shamrock CCD
>> > > error = ShamrockInitialize("");
>> > > if(error!=SHAMROCK_SUCCESS){
>> > > ...exiting" <<endl;
>> > > ShutDown();
>> > > return(1);
>> > > cout << "Shamrock ready!" << endl;
>> > > int nodevices(0);
>> > > ShamrockGetNumberDevices(&nodevices);
>> > > if(nodevices < 1) {
>> > > cout << "No Shamrock detected...exiting" <<endl;
>> > > ShamrockClose();
>> > > ShutDown();
>> > > return(1);
>> > > Han anyone had similar issues?
>> > > Thanks,
>> > > Hinko
> .. the more I see the less I believe.., AE AoR
- Re: Andor shamrock not detected Mark Rivers
- Andor shamrock not detected Hinko Kocevar
- RE: Andor shamrock not detected Mark Rivers
- Re: Andor shamrock not detected Hinko Kocevar
Event triggers for plusers not detected (mrf-timing system) Karim Laihem
<2017>
2025
2026
<2017>
2025
2026
