Subject: Re: caget() from C++
To: Mark Rivers <[email protected]>, "'Kasemir, Kay'" <[email protected]>, Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Cc: "Mendez, Jennifer M" <[email protected]>
Date: Wed, 6 Dec 2017 03:33:09 +0000
So, indeed, the warnings go away when I set EPICS_CA_AUTO_ADDR_LIST=NO. However, no matter if I use my eth0 or eth1 broadcast address, I can not use camonitor on either set of IOC’s PVs.
Along these lines, I tried to read Kay’s 2012 post (http://www.aps.anl.gov/epics/tech-talk/2012/msg02356.php), that motivated the following effort:
I tried firing up IOC1 with EPICS_CA_ADDR_LIST=eth0bcast:5065, EPICS_CA_ PORT=5065 and IOC2 with EPICS_CA_ADDR_LIST=eth0bcast:5066, EPICS_CA_ PORT=5066, and in the session where I run camonitor I say EPICS_CA_ADDR_LIST=” eth0bcast:5066”. I also tried it with eth0->eth1.
camonitor fails when I do this, and CSS and archive-engine do also. Only, it seems, if I set EPICS_CA_ADDR_LIST=localhost can I use camonitor, and only then on the PVs of the second IOC that I fire up.
What is so non-standard about my network on this everything-on-one-computer setup of mine? Does a firewall even matter in this case?
- Eric
On 12/5/17, 2:45 PM, "Mark Rivers" <[email protected]> wrote:
    If you set the EPICS_CA_ADDR_LIST to the broadcast address then you must also set EPICS_CA_AUTO_ADDR_LIST=NO.  That is why you are getting these warnings, because these broadcast addresses were already being used because EPICS_CA_AUTO_ADDR_LIST was defaulting to YES.
    Warning: Duplicate EPICS CA Address list entry "192.168.1.255:5064" discarded
    Warning: Duplicate EPICS CA Address list entry "130.20.49.255:5064" discarded
    > -----Original Message-----
    > From: Church, Eric D [mailto:[email protected]]
    > Sent: Tuesday, December 05, 2017 4:06 PM
    > To: Mark Rivers; 'Kasemir, Kay'; Ralph Lange; EPICS Tech Talk
    > Cc: Mendez, Jennifer M
    > I attach a file showing my efforts at setting this variable in the xterm session in which I run
    > my caxyz commands and the record of my puzzling problems. Before trying to export these
    > values of EPICS_CA_ADDR_LIST, all was well. Whereas, after setting it, failingx2, if I
    > unset it I can not connect: I am not returning to successful camonitoring of just even one
    > IOC.
    > Note: all the relevant-looking complaints from my 2nd IOC terminal in the attached file ….
    > - Eric
    > On 12/5/17, 1:43 PM, "Mark Rivers" <[email protected]> wrote:
    >     > Looks like the EPICS_CA_ADDR_LIST used by camonitor is not using the broadcast
    > address of your host.
    >     It should be doing that automatically without you needing to set
    > EPICS_CA_ADDR_LIST.  Can you send the output of the following commands Linux
    > command in the shell where you are running camonitor.
    >     ifconfig
    >     printenv | grep EPICS
    >     At the IOC shell prompt on both the first and second IOCs send the output of
    >     epicsPrtEnvParams
    >     What happens if you set EPICS_CA_ADDR_LIST manually to the broadcast address of
    > your system?  For example on my system ifconfig shows:
    >     p5p1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    >             inet 164.54.160.82  netmask 255.255.255.0  broadcast 164.54.160.255
    >             inet6 fe80::3efd:feff:fea3:f258  prefixlen 64  scopeid 0x20<link>
    >             ether 3c:fd:fe:a3:f2:58  txqueuelen 1000  (Ethernet)
    >             RX packets 80276465019  bytes 92598173910474 (84.2 TiB)
    >             RX errors 0  dropped 114  overruns 0  frame 0
    >             TX packets 32261858165  bytes 16671972218313 (15.1 TiB)
    >             TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    >     So I would set EPICS_CA_ADDR_LIST=164.54.160.255
    >     Mark
    >     > From: Kasemir, Kay [mailto:[email protected]]
    >     > Sent: Tuesday, December 05, 2017 3:37 PM
    >     > To: Church, Eric D; Mark Rivers; Ralph Lange; EPICS Tech Talk
    >     > >Indeed camonitor can properly watch a channel on the first IOC when only it is
    > running. I
    >     > can dial up and down the voltage from CSS on a particular PV on this first IOC and
    > watch
    >     > it move on camonitor. >When I start the second IOC I can continue this exercise on
    > POVs
    >     > on the first IOC. If I kill camonitor, per your suggestion, I can not start it again on a PV
    > on
    >     > the first IOC. And if I kill the second IOC I can >once again start camonitor
    > successfully on
    >     > a PV on the first IOC.
    >     > >What does it mean, do ya think?
Re: caget() from C++ Mark Rivers
caget() from C++ Church, Eric D
Re: caget() from C++ Andrew Johnson
Re: caget() from C++ Church, Eric D
RE: caget() from C++ Mark Rivers
Re: caget() from C++ Ralph Lange
Re: caget() from C++ Kasemir, Kay
Prev: Re: EPICS 7 Release Candidate 1 Michael Davidsaver
Next: Re: caget() from C++ Mark Rivers
Prev: RE: caget() from C++ Mark Rivers
