1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Event triggers for plusers not detected (mrf-timing system)
To: Karim Laihem <[email protected]>
Date: Wed, 13 Dec 2017 18:50:56 +0000
On second thought, I may see a problem after all…
On Dec 11, 2017, at 12:15 AM, Karim Laihem <[email protected]> wrote:
mrf-TEST-EVG0:TrigEvt4-Enable-RB Enabled
mrf-TEST-EVG0:TrigEvt4-EvtCode-RB 0
It looks like you are using trigger 4 to send the event, but the event code you are “sending” is 0 — which is the “null” event.  I think it should be set to “4” if you want the EVR to see an event 4.
-Bj
Event triggers for plusers not detected (mrf-timing system) Karim Laihem
Prev: Re: Event triggers for plusers not detected (mrf-timing system) Bjorklund, Eric A
Next: modbus: problem on readInt32Array Davide Marcato
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: How to migrate old data from channel archiver to archiver appliance Heinz Junkes
