Subject: modbus: problem on readInt32Array
To: [email protected]
Date: Thu, 14 Dec 2017 13:58:41 +0100
Hello,
I am writing an asynPortDriver port on top of the modbus EPICS module and I would like to read the initial values of the modbus registers for writing functions.
I am currently working with modbus 2-10-1 and asyn4-30 and I am using the absolute addressing. I noticed that when calling readInt32Array on the modbus port using modbus function 16, the module always performs a TCP query but does not return the values, because it enters the following lines of code:
drvModbusAsyn.c line 1276:
                case MODBUS_WRITE_SINGLE_REGISTER:
                case MODBUS_WRITE_MULTIPLE_REGISTERS:
                case MODBUS_WRITE_MULTIPLE_REGISTERS_F23:
                    printf("write multiple registers\n");
                    if (!pPlc->readOnceDone) return asynError;
and readOnceDone is false. This way I can never read the initial values of the registers. Is this a know behavior or is it an error?
In the readInt32 function (drvModbusAsyn.c line 878) the variable readOnceDone is set to 1 after the call to doModbusIO. Is there a reason for not being the same on the readInt32Array function?
Furthermore, would it be a good idea to avoid performing modbusIO more than once in absolute addressing mode when using a write modbus function (eg: 16)? This would keep the behavior consistent with the rest of the module.
I also noticed that on the rest of the module, when trying to read on a "output" port (meaning that a modbus write function code is in use) the module always return the value it read at startup, on the first (and only) reading. Is there a reason why the values written to those registers are not cached and the last written value is returned instead of the value the register had on the first reading? I mean somenthing like:
1 - the registers are read (doModbusIO) and their value is saved to a cache
2 - the user writes to some of those registers
3 - the user tries to read those same registers and the modbus module returns the last cached value for each register
Thank you,
Davide
Davide Marcato
INFN - Laboratori Nazionali di Legnaro
Viale dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Phone: +39 0498068439
Prev: Re: Event triggers for plusers not detected (mrf-timing system) Bjorklund, Eric A
Next: Channel Archiver compilation error Wang, Lin
Prev: Re: Save MCA record data Mark Rivers
