1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aCalcout AVAL monitors
To: Bruno Martins <[email protected]>
Date: Mon, 18 Dec 2017 21:01:18 +0000
Hi Bruno,
That would be great.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Monday, December 18, 2017 2:44:08 PM
To: Mooney, Tim M.
Cc: [email protected]
Hi Tim,
Sounds like the perfect solution! Would you want me to open a pull request?
Bruno
On Mon, Dec 18, 2017 at 3:34 PM, Mooney, Tim M. <[email protected]> wrote:
Hi Bruno,
This seems a good improvement.  How about this: if any array element has changed by MDEL or larger, the array is posted with DBE_VALUE, and
if any array element has changed by ADEL or larger, the array is posted with DBE_LOG.
From: [email protected] <[email protected]> on behalf of Bruno Martins <[email protected]>
Sent: Monday, December 18, 2017 2:24:00 PM
To: [email protected]
Subject: aCalcout AVAL monitors
Hi everyone,
If VAL doesn't change between processings, acalcout doesn't post a monitor event to it, unless MDEL is set to -1 (as expected).
However, the same is not true for AVAL. Even with MDEL set to -1, if AVAL doesn't change I get no new monitor events. Here's the relevant code in the calc module:
https://github.com/epics-modules/calc/blob/master/calcApp/src/aCalcoutRecord.c#L983
This has come up before, and Tim Mooney explained it here:
So my question is: shouldn't AVAL's behavior follow VAL's? Or at the very least, shouldn't there be a mechanism to force AVAL to update?
Bruno
aCalcout AVAL monitors Bruno Martins
Re: aCalcout AVAL monitors Mooney, Tim M.
Re: aCalcout AVAL monitors Bruno Martins
Prev: Re: aCalcout AVAL monitors Bruno Martins
Next: Re: Puzzled with lockset(?) problem Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Helium Purity Sensors austen.rose
