1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Puzzled with lockset(?) problem
To: Michael Davidsaver <[email protected]>, EPICS <[email protected]>, "Mooney, Tim M." <[email protected]>
Date: Tue, 19 Dec 2017 16:43:58 +0100
On 18.12.2017 19:34, Mooney, Tim M. wrote:
 I don't understand what's happening, but I have a clue:  If you write to "mode" directly from an aSub output link, the database behaves as it should.
Interesting.
Also if I scan the aSub directly rather than with a monitor it works as expected. BTW: Making the links from and to the mode record CA (and thus breaking up the locksets) does not help.
On 19.12.2017 00:46, Michael Davidsaver wrote:
Needless to say, my first advice is to be careful about using seqRecord in a loop!
Or any records in a loop. :-)
Thanks for your replies.
I rather wrote the code to make the record asynchronous (when in re-initialization mode). That works well and also does not illegally delay record processing.
Dirk
Puzzled with lockset(?) problem Dirk Zimoch
Re: Puzzled with lockset(?) problem Michael Davidsaver
Prev: Re: Channel Archiver compilation error Heinz Junkes
Next: VisualDCT not starting on RHEL7 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Puzzled with lockset(?) problem Michael Davidsaver
Next: EPICS Releases (two!) Andrew Johnson
